Thread: car wont start ....all does is fart
Page 2 of 2 FirstFirst 12
Showing results 21 to 38 of 38
    RydnClean
    my car does run.....somtimes..... but REAL rough, im jus tryna sell my car because i dont have 500 to replace a distributor, i have no clue what a water sensor is...where is it? and how much are they to replace?
    <div class='quotetop'>QUOTE(RydnClean)</div><div class='quotemain'>my car does run.....somtimes..... but REAL rough, im jus tryna sell my car because i dont have 500 to replace a distributor, i have no clue what a water sensor is...where is it? and how much are they to replace?</div>
    man, you cant just guess as to whats wrong and start replacing sensors. there are literally a hundred different things that could cause that problem. you HAVE to have it checked out professionally, as youll spend hundreds (or thousands) of dollars just randomly replacing componants (which may not be the problem anyway... it could be a damaged wiring harness, or something similar)
    I didn't say replace it... I said check it...
    *CHECK* it.... Then if it's not operating correctly, replace it.
    Craig R.
    1996Galant 14.0@103
    biggest b00bies EvAr
    IllestGalant
    your gonna have to narrow it down buddy, There are about 700 reasons why an engine will have a crank and no start condition.
    RydnClean
    could it possibly be the distributor cap and not the whole thing?
    <div class='quotetop'>QUOTE(RydnClean)</div><div class='quotemain'>could it possibly be the distributor cap and not the whole thing?</div>
    yes.
    that leave 699 other pieces it could be if it doesnt fix it.
    RydnClean
    well i talked to a mechanic today, he didnt look at it or anything but he said it sounds like my timing belt jumped? how could that have happened? i didnt even drive the car but 2 times.
    Quote Originally Posted by RydnClean
    yes, it could have. timing belts just break, as they are wearing items. thats why theyre suppost to be replaced every 60000 miles.
    look, man... not to be rude here, but if you keep coming here and asking what could be the problem, youre never going to get it fixed. it needs to be PROFESSIONALLY looked at.
    bongi
    :oops: that is the reason he goes to these pages to check if there are common complaints in the galant model and i will not blame him. go to the dealer and you will be tacked with so many parts to replace, unnecessary parts( believe me ) and you end up having the same problems again. just because distributors have been replaced 7000x mean anything. if at all, other parts can be defective. temperature sensors are all hooked up together that to pinpoint the actual one you have to do several tests to isolate the problem. it is wired to the a/c control, the transmission(if you have an oil cooler), the radiator fan and name it it is somehow wired in series. an easy way is to check the resistance in ohms if it at specs. if it is the distributor, it will run at all which is the same as having no gas in your lines. so, check everything before assuming it is a $500 part. as for the timing belt, you can check for teeth if it is worn out by taking out the cover. jumping timing belt is possible but uncommon.
    <div class='quotetop'>QUOTE(bongi)</div><div class='quotemain'>:oops: that is the reason he goes to these pages to check if there are common complaints in the galant model and i will not blame him. .</div>
    first, ive already told him the most common failures. and just because something is common DOESNT mean its the problem hes having. by the time hes purchased a new coolant temp sensor, distributor cap, and half dozen other items (which may or may not fix the problem), he could have just spent 90 bucks to have it checked out anywhere that knows mitsus.
    <div class='quotetop'>QUOTE</div><div class='quotemain'>
    </div>
    i suggest you find a better dealership. or perhaps just get a better mentality about the whole thing, as i have NEVER just thrown parts at a car to fix it. i diagnose the problem, and give people estimates to fix it. its entirely up to them to make the choice as to wether or not they will let me fix it.
    Â*just because distributors have been replaced 7000x mean anything. if at all, other parts can be defective. </div>
    thats my point exactly. it needs to be PROFESSIONALLY checked
    <div class='quotetop'>QUOTE</div><div class='quotemain'> temperature sensors are all hooked up together that to pinpoint the actual one you have to do several tests to isolate the problem. Â*it is wired to the a/c control, the transmission(if you have an oil cooler), the radiator fan and name it it is somehow wired in series. an easy way is to check the resistance in ohms if it at specs. </div>
    actually, thats somewhat incorrect. its true that the current mitsus use only 1 coolant temp sensor for the engine, fans, and AC, but earlier ones had a seperate sensor for all 3. Also, the trans has its own temp sensor and always has.
    <div class='quotetop'>QUOTE</div><div class='quotemain'> if it is the distributor, it will run at all which is the same as having no gas in your lines. so, check everything before assuming it is a $500 part. </div>
    thats also not true. most of the time they ilde fine, but wont run correctly under load. sometimes they work fine until warmed up, then suddenly die, and other times they wont start at all. and once again, ive said 5 times to make SURE its the distributor before just throwing 500 bucks at your car.
    <div class='quotetop'>QUOTE</div><div class='quotemain'> as for the timing belt, you can check for teeth if it is worn out by taking out the cover. jumping timing belt is possible but uncommon.</div>yes, you can check the teeth by taking off the cover. you can also check to see if the cam is turning by just removing the oil cap whilst the engine is cranking, but this may not be accurate as the timing could have jumped, but still has enough tension to turn the camshaft.
    also, broken timing belts are one of the most common failures we see on high milage cars, as very few people ever maintain them as theyre suppost to.
    so, once again i simply must suggest a professionaly diagnosis by a known competent mechanic. there are simply far to many things that could be at the root of this guys problems to just throw parts at it.
    bongi
    there two mentalities when bringing the car to the dealership or any shop, the mechanic will diagnose the problem and throw everything that needs to be replaced if to him it is necessary without considering the cost. that means shotgun treatment and if it fixes the problem, very good job indeed! the owner considers the cost of the repair and the problem that needs to be resolved. if it is your company's car, you can do whatever you like, if it is coming from your pocket, you must be at least cost-effective or efficient in the repair.
    <div class='quotetop'>QUOTE(bongi)</div><div class='quotemain'> there two mentalities when bringing the car to the dealership or any shop, the mechanic will diagnose the problem and throw everything that needs to be replaced if to him it is necessary without considering the cost. that means shotgun treatment and if it fixes the problem, very good job indeed! Â*the owner considers the cost of the repair and the problem that needs to be resolved. Â*if it is your company's car, you can do whatever you like, if it is coming from your pocket, you must be at least cost-effective or efficient in the repair.</div>
    as i said before, id highly suggest you find a different shop. Im not sure what kind of people you take your cars too, but if we were to run our business like that, we wouldnt have survived 10 years +.
    no, in fact, that is NOT how its done at a reputable place of business. Once again i will say that when a customer comes in for a problem, we charge a flat 90 dollar diagnostic fee, reqardless of the complaint. After i figure out what the problem is, i will then create an estimate based on my findings (I.E, if i found a failed distributor, i would estimate a new one).
    thats all there is to it. any decent tech can easily diagnose a car with a lab scope and a wiring diagram.
    a dealership is NOT just going to "throw parts" at a car, as its not cost effective.
    Lets get back to the topic here guys and not what some dealerships might do. Manybrews is giving sound advice. I would take it to a shop IMO.
    Jason
    www.edelhausrottweilers.com
    hmmm my car used to do that too and i like did everything you did pretty much with my old car which was an oldsmobile. after 2 months of getting pissed off i went to the dealer and said it was the wrong fuel... freaking shit it was probably when my mom drove da freaking car and accidentally got diesel... shit how can you make a mistake but now i got my g because of her and everything is better now soo try checking on that???
    uhhhh...... Whats a 9g???
    RydnClean
    where can i get a used distributor from? any1 have a good online junkyard? and would one from a 92 galant work?
    <div class='quotetop'>QUOTE(RydnClean)</div><div class='quotemain'>where can i get a used distributor from? any1 have a good online junkyard? and would one from a 92 galant work?</div>
    1) a junkyard
    2) no, i dont know any
    3) no, it wont
    and you STILL havent had it checked out?
    are you seriously not willing to spend the 80 bucks for a diagnosis, and would rather spend upwards of hundreds of dollars just throwing parts at it?
    RydnClean
    well guess what........i FINALLY fixed it....and nope i never got it checked out or wasted 80 dollars for a diagnosis, nuthin personal but im only 17 and my pockets dont roll that deep.....the problem was a plug on my distributor was cracked, so we took it off squeezed it together and put shoe goo on it and taped it up really tightly with duck tape. problem fixed runs fine now......i also fixed my squeeling problem that was my alternator belt and it was worn out off track and that caused the belt to slip and squeel. got a new one 10 bucks and everything sounds and runs fine!
    thanks alot for all of yall help tho!
    Excellent job! :thumbsup: Amazing what a little detective work and some elbow grease will do and save you. :mrgreen:
