Thread: 8G parts list that will fit our cars (ITS ALL HERE)
Showing results 1 to 20 of 25
    hey all i no im still a noob on this site, but ive owned an 8g since 2000. ive pieced together a list of performance parts that noobs can use on the 4g64 engine. ill just name the companys i no of that manufacture the part. im sure theres lists here on this site to find all of these, but i like a list that just says "ok this fits" lol. i guess first ill start with where to find all your OEM parts first :shock:
    MITSU OEM PARTS: ALL OEM parts for ALL MITSU VEHICLES
    https://www.mitsubishiparts.com/index.php
    http://www.mitsubishiparts.net/
    http://shop.mitsubishipartstore.com/
    JDM PARTS: good website to search for jdm mitsu parts as well as jdm parts in general.
    http://japanparts.com/
    COOL AIR INTAKES: Injen, Weapon-R, AEM
    http://tearstone.com/shop/
    INTAKE MANIFOLD: RPW Performer Intake Manifold for 4g64 or 6g72(careful with this item as it may not have the EGR on it, but they can machine one onto it for u).. Tearstone carries the RPW Performer IM for the 6g72 motor. Rippmods had a prototype they were working on for the 8g but scrapped that project i think. an IM from a 2003 mitsubishi outlander can be swapped along with its throttle body to our engine as well. (thanks Run1206 and Sleepervr-4)
    http://www.rpw.com.au/
    http://rippmods.com/
    THROTTLE BODY: RPW has one u can get or exchange for a bore on ur stock one, couple other cars in the mitsu lineup have TB's that can also be swapped. check threads on this one but like i said this is just bolt up an go parts lol
    4G64 STROKER KIT: Brian Crower racing has a kit to stroke the block from a 2.4l to a 2.6l
    http://briancrower.com/view.php?pn=BC0110
    CYLINDER HEAD INTERNALS: RPW camshaft, RPW valve Springs, 4G63 EZ on ebay makes 'SS' swirl finished valves u can buy at a good price. plus they sell bronze guides and viton blue valve seals u can use for the 4g64. many others for valves but the sky can be the limit.
    http://stores.ebay.com/Hi-Performanc...t-Engine-Parts
    CYLINDER HEAD EXTERNALS: Cam Gear: Aem, Vernier (RPW), OBX
    http://search.ebay.com/search/search...ear&category0=
    OPTIMA BATTERIES: Red Top ( use size D75-25 ). Yellow Top deep cycle ( use size D34-78 ). you can also use the Yellow Top deep cycle D75-25 as well although it has slightly lesser cold cranking amps than the D34-78 but the D75-25 has the top posts in easy areas for mounting the positive an negative wires.
    http://www.advanceautoparts.com/
    http://www.autozone.com/home.htm
    SPARK WIRES: Magnecor
    http://www.amazon.com/Magnecor-45182.../dp/B000ECU55Y
    ALTERNATORS HI-AMP (for stereos): i only really no of 3, ohiogen.com, i believe u can order one for a dodge stratus (01-05) from powermaster or there is a guy who specially makes them i can recommend that i found on this website named Dominick Iraggi. word of pre-caution, hi-amp alternators for our cars are super expensive, they run from 400-800 bucks from what ive seen. what u can also do is take your stock alternator to an electrical shop an have them respin it. thats the most cost effective. our stock alternators spin at 90 AMPS. i was quoted $250 to respin my alternator at 140 AMPS an they will attach a smaller pulley so it spins faster at idle.
    http://www.ohiogen.com/index.html
    http://www.powermastermotorsports.co..._high_amp.html
    Irragi alternators
    n/a
    LaVergne TN
    Phone: 615-287-7991
    Email: [email protected]
    Contact Name: Dominick Iraggi
    FUEL PRESSURE REGULATORS: Aeromotive, Weapon R (universal but nice that it comes with a gauge), many others
    http://cgi.ebay.com/ebaymotors/Weapo...QQcmdZViewItem
    FUEL RAIL: RPW DOES make one. must call about this item, but ive called an yes they do manufacture one. can use any EVO 4-9 fuel rail but will need spacers.
    http://www.erzperformance.com/product_p/ap-ct9a-120.htm
    FUEL INJECTORS: too many to mention, RC, DSM, RRE, Blitz, Accel, just need to no if there high impedence or low impedence
    http://hahnracecraft.com/
    http://www.erzperformance.com/RC_Injectors_s/412.htm
    EXHAUST HEADERS/ CAT BACKS: BE CAREFUL as the 8G has 2 different exhausts specs, Cali Spec an Fed Spec. (cali spec is 2 cats with a small pre-cat up front an a regular cat underneath the car... the fed spec is 1 cat). i put ebay on here for the Megan cat back and OBX header, if u go to ebay for these items, type in "galant drift spec" (should be a few available at $330 +shipping) and "galant obx header" ...other headers to be found are...
    Kamikaze, RPW, Rippmods (V6 only), DC Sports (look up the one for the eclipse from 00-04)
    http://www.ebay.com/
    http://www.andysautosport.com/mitsub...ders/kamikaze/
    FUEL PUMP: Walbro GSS342 255 LPH (in-tank). will have to do a minor modification on it to be a direct drop in. ill attach that thread to this.
    http://tearstone.com/shop/Fuel-Pump-...us/Galant.html
    PULLEYS: AEM (alt. pulley an water pump).. ive searched on this an u can buy pulleys for a 2g eclipse 4g63 an they will bolt up to our motors. just be wary of the crank pulley as it has a harmonic dampener built in. Buschur Racing has a crank pulley with it built into theres. Obx and Unorthodox Racing are the only companies i no of who have FULL SETS of pulleys for the engine with P/S, Crank, Alt, Water pump included.
    http://unorthodoxracing.com/
    http://www.machv.com/aemtrupowacp.html
    http://www.modacar.com/products/Mits...g+Ultra+S.html
    BRAKES: Rotora, HP Racing, K-sport, Powerslot, can swap the evo calipers & rotors on both front an back but F that, i think its pointless to do that when u can run into clearance issues from rim to caliper. For the stock rear drums on our cars u can convert them to disc as well, very easy to do with minor modification. ive got a thread from Run1206 on how he did his conversion. his is the most detailed, w/pics as well, so ill post it on here.
    http://www.ksportusa.com/asp/brake_kits.asp
    http://hpracing.com/
    http://rotora.com/cgi-local/SoftCart...html?E+scstore
    http://galantforums.com/modules.php?...&p=16984#16984
    BRAKE LINES: Goodridge, SSBC, Stoptech
    ENGINE TORQUE DAMPENER: Ingalls Stiffy (V6 only, order as Eclipse 00-05)
    http://tearstone.com/shop/Torque-Dam...6-Eclipse.html
    STRUT TOWER BAR: Freedom Designs, Megan Racing, DC Sports, any 00-04 Eclipse FRONT upper strut bar will fit.
    http://www.freedomdesign.com/Merchan...e=strutbraces3
    http://www.horsepowerfreaks.com/pric...rut_Tower_Bars
    http://www.horsepowerfreaks.com/pric...-_Carbon_Steel
    SWAY BARS: Intrax (rear only), Addco (rear only). i cant seem to find a website whom has the addco bar but ill post there list of mitsubishi cars they manufacture them for.. 99-02 Galant part# 02149..
    http://www.racepages.com/products/in...r&No=10&Npp=10
    http://www.addco.net/Kia-Mitsubishi_...htm#Mitsubishi
    SHOCKS / STRUTS: Koni (must order as 00-04 eclipse), Kyb (can order AGX as 00-04 eclipse)
    http://www.modacar.com/products/Mits...clipse/MODASHS
    CHASSIS STIFFENING: D3 Designs makes a full kit for the 8g.
    http://www.dthreedesigns.com/shoppin...sword=Guest#4b
    SPRINGS: too many to list, ill name 5.. Progress, Tein, Intrax, Eibach, Sprint.. i put ebay because springs are a dime a dozen. when u go to ebay, type in "galant spring" an u can scroll thru the 1000s' that are always available. ive seen Tein S.techs on there for both the 4cyl an 6cyl for as low as 140 dollars.
    COILOVER SLEEVES / FULL DAMPENERS: Ground Control, Skunk 2, K-Sport (Full dampening), Tein (order the ones for 00-04 eclipse full dampening) Megan Racing (Full Dampening), D2 (Full Dampening), G4 (Full Dampening).. if u go ebay, type in "galant coilovers"
    http://www.nolimitmotorsport.com/prod/D2-M11
    http://search.ebay.com/search/search...ers&category0=
    TRANSMISSION: Rezlo Torque Convertor sold by Tearstone, Level Ten makes a 'bullet proofing' kit as well as doing tranny fabrication work or u can swap the auto (F4A22) for an 00-04 Eclipse (NVT350) 5-Speed. Huge article on this site with pics to show how that is done an parts list as well. ill post that on here.
    http://www.levelten.com/
    https://thegalantcenter.net/forum/viewtopic.php?t=42078
    TURBO KITS: Dougs Dyno Power has one, some people liked it, some didnt. friend of mine in Maryland has one an it dynoed at 256 HP to the wheels on 11 PSI. RPW now manufactures a kit for the 6G72/74 motors as well. Max-Rev motorsports has a 4g64 turbo kit as well with a V6 kit planned, (order as 00-04 eclipse). Turbo Specialties carrys a kit for the 6g72 motor as well. u can also do ur own custom set up, some guys on this site have swapped EVO parts to our engine an gotten a substantial bang for there buck. Goosey2099 has done a swap like this an has a parts list an pics to backup his work. his swap was prolly the most cost effective as well. ill post that thread on here also.
    http://www.ddynopower.com/
    http://www.statracing.com/apps/mitsu...turbo-kits.asp
    http://www.maxrev.com/catalogs/01-Mi...lipse-4G64.pdf
    https://www.thegalantcenter.org/viewtopic.php?t=60359
    SUPERCHARGERS: Rippmods has kits for the 6g72 motor. Most people who've bought the kit from them say 1 thing in common, get it an upgrade the fuel system an dont use the black box they provide u with. most people have said switch to the greddy e-manage ultimate, walbro fuel pump an big injectors.
    ENGINE MOUNTS: Deyeme Racing about 300+ dollars (must order as 01-05 stratus/sebring).. comes with urethane inserts u can order in different colours
    http://www.deyemeracing.com/products.asp
    PISTONS: CP, Ross, Wiseco, fantastic website called Import Performance Parts (IPP) where u can buy grade A level gaskets an performance gasket kits with pistons an rods.
    http://importperformanceparts.net/
    CONNECTING RODS: almost any 2g eclipse rods will fit the engine just watch for clearances on some brand manufacturers. as far as i no u can buy Eagle Rods for the 2g eclipse with zero clearance issues and put them in our motor
    CRANKSHAFT: Eagle has one
    ECU UPGRADE: AEM Ems, Greddy E-manage or E-manage Ultimate, JET can chip the stock ECU if u like, venom 400 module
    http://www.jetchip.com/
    DRESS UP: Tearstone.com has a set of billet bottle cap covers, hose techniques (wire loom, silicone hoses), deyeme racing has some radiator brackets in multiple colours an some minor stuff (order as 01-05 stratus/sebring) , Killer Glass (they literally have see thru glass hoses) , Injen has an oil cap and fuse box cover.
    http://tearstone.com/shop/Tearstone-...-products.html
    http://killerglass.com/
    http://www.boneheadperformance.com/a...jendressup.htm
    QUICKLIFT HOOD PROPS: redline tuning
    http://www.redlinetuning.com/QL-MITSU-GALANT-9903.html
    RACING SEATS: Bride, Otto-R, Sparco..u can swap the FRONT seats from an 00-04 eclipse right into an 8g, they will bolt right in. be careful getting a power adjustable seat due to wiring issues as well as the seats are more padded an can bump into the door when it closes, but that said u can order almost any 00-04 eclipse racing seat. ill load up the article of the man who swapped a seat from an 00-04 eclipse into his 8g.
    http://www.andysautosport.com/racing...hi_galant.html
    https://thegalantcenter.net/forum/vi...168&highlight=
    NEW PRE-MOLDED CARPET: this one is out of place but ive been asked about this one before where or if they make a replacement fully pre-molded carpet for the 8g.. yep they do. theres a couple places ive found. u can go to auto-interior.com or go on ebay. ive posted the link to the ebay store that sells pre-molded carpet for our cars.
    http://www.auto-interior.com/mitsubishi8.htm#galant
    http://stores.ebay.com/Auto-Carpet-Professionals
    ADDED! ADDED! ADDED! ....... 10/17/2007.......
    Heres some carbon fiber stuff everyone asks about u can find, mostly on ebay they have alot of stuff that is easy to come by, usually thats my spot for almost everything. but im sure theres 1000 sites u can go to find cheaper im just putting it out there so u can see that stuff is available. first an foremost ill start this off with HOW TO MAKE UR OWN PROJECTS :D
    heres the article i gathered from this site on HOW TO MAKE YOUR OWN CF PROJECTS!!! 8) ...
    article: http://www.racingcomposites.net/unt?id=505
    CARBON RACING SEATS: Bride, Otto-R, Sparco..u can swap the FRONT seats from an 00-04 eclipse right into an 8g, they will bolt right in. be careful getting a power adjustable seat due to wiring issues as well as the seats are more padded an can bump into the door when it closes, but that said u can order almost any 00-04 eclipse racing seat. ill load up the article of the man who swapped a seat from an 00-04 eclipse into his 8g.
    CARBON HOOD / TRUNK : Vis Racing (has oem hood or EVO style an Monster Style) , Seibon Racing. or go ebay an type in "galant carbon hood". for the trunk on ebay type in "galant carbon trunk"
    http://visracing.com/index_browse.html
    http://www.seiboncarbon.com/
    CARBON MIRRORS : can use any 94-97 mirrors from a honda accord though the black plate will need modifying as well as wiring, ganador mirrors from a mitsu legnum (must alter wiring and its from a UK website, although i do believe they accept american money) or VIS now has carbon fiber (special order) or fiberglass 'ganador style' mirrors. if u go ebay for the honda mirrors, type in "accord carbon mirror".
    http://www.neweraparts.com/Default.a...&ProductID=165
    CARBON GEAR SHIFTER / E-BRAKE KNOB: can buy a universal off ebay (simple way out) an then trim the plastic stick underneath the stock knob. u will also need to trim the vinyl on the stock ebrake if u use a universal. Levoc makes a few although not certain on there fitment. if u go ebay type in "carbon automatic shift knob". for the e-brake type in "carbon e brake".
    http://www.napolex.com/
    CARBON TWILL: go to ebay an type in "carbon fiber twill" u can get a decent roll that has good quality for cheap. the 6 ounce is usually a good roll to go with if available.
    CARBON TAILLIGHTS: TYC makes them for our car. im using the ebay link because plain an simple, cheapest place to get them. type in "galant taillight".
    CARBON FIBER MUFFLERS: ebay, hks, list is endless for that. if ebay, type in "carbon muffler". the hks carbon muffler is one badass piece though.
    http://www.hksusa.com/products/?id=1733
    CARBON GAUGES: speedhut or blackcatcustom, ebay (they have the AC Autotechnic S7s' and some random el-glow type gauges). if u want the AC Autotechnic S7 gauges, u can go on ebay and type in "galant s7 gauge".
    http://www.speedhut.com/Default.asp?bhcp=1
    http://www.blackcatcustom.com/index.htm
    CARBON BEZELS: speedhut or go ebay.. if u go ebay, type in "galant carbon bezel"
    CARBON DASH OVERLAY PIECES: ebay (mostly cheap stick ons but not easy to find full replacements ). type in "galant carbon dash trim"
    CARBON FENDERS: they have multiple carbon fiber fenders for the 99-03 now on NOPI.com or go to Erebuni.net, but be careful with fitment. i got the fiberglass version Z3 fenders from them an had to do some minor adjustments. MUST CALL FOR THESE ITEMS, THEY WILL NOT BE LISTED ON THE WEBSITES!!!
    http://www.nopionline.com/nopistore/index.cfm
    http://erebuni.net/
    CARBON GAS DOOR: ebay from time to time has one for the car that is true carbon fiber an the seller is a place called KarbonKoncepts. when u go on ebay u can simply type in "galant gas door". this link i put on here is for karbonkoncepts actual store, i figure if u try to find the door by typing it in an nothing happens, u can email karbonkoncepts.
    http://stores.ebay.com/KarbonKoncepts :D :shock:
    04-10-2005
    NYC
    3,695
    i applaud you on doing this but there is already a thread for a parts list, you could have just added it into there, as well as some places to buy them from...
    ya i read some of the threads here on parts lists, i wanted a place u could just ok this fits, those threads were scattered, i wanted to make something concrete. as far as places to buy from, this is the internet. i could list 1000 websites an someone will say i found it cheaper here or there. i figured id just put the part companys an people could find the right pricing on there own. but ya ur way was a possiblity to. ah well like i said IM A NOOB ON THIS SITE LOL :mrgreen:
    we used to have a master list in excel format but it got lost when the board died about 4 boards ago.
    finally a smart noob!!! :D
    00 Galant ES Turbo/5-Speed
    13 GTR
    04-13-2005
    Chicago
    1,945
    Re: 8G parts list that will fit our cars (NOOB)
    Quote Originally Posted by Trevs56
    Cool Air Intakes: Ingen, Weapon-R, AEM
    :oops: :oops: :oops: :oops: :oops: :oops:
    n3oAcid24 = 01' Galant I4
    so some of the 00-04 eclipse parts are interchangeable to 8G parts? am i getting that right? if so, what can be substituted?
    04-13-2005
    Chicago
    1,945
    Quote Originally Posted by deejunx
    yes, but i am not telling you what. read the whole thread and you will find out.
    sweet. thanks
    08-15-2006
    Perth Amboy, NJ
    1,558
    Trevs56: don't forget to include that the Intake Manifold from the Mitsubishi Outlander can be swapped with our stock IMs. Sleepervr-4 and I have done the swap (better throttle response and slightly bigger TB). photobucket's going through maintenence for now, but i'll post a pic of my setup when PB's back up.
    run1206's Rear Disc Tutorial
    TGC Regular Gladiator's Avatar
    03-19-2003
    Rego Park Queens
    443
    someone should sticky this
    Quote Originally Posted by run1206
    ya my bad dude, like i said i was just posting my direct knowledge. ill continue to add on stuff i find. and/or edit anything ive made a mistake on. they locked my add on my 8g for sale. i no longer live in america but im gonna try to build a galant over here in norway. but ill continue to post stuff i find on this list. ill edit that intake manifold thingy right now.
    08-15-2006
    Perth Amboy, NJ
    1,558
    k, here's my setup ( for now)...
    thats a slick mod, when u got the outlander IM did u try to port it out more? or did u leave it as is?
    08-15-2006
    Perth Amboy, NJ
    1,558
    i left it as is for now, although i think i might port it out after my turbo install...
    Member JDM4G64T's Avatar
    07-09-2007
    Fort Lauderdale, FL
    324
    Nice work Treb!!!! :D
    Car is sold, no more G.... Moved on to something a big more sporty.... lol
    Will the eclipse Megan racing headers fit a 2002 galant 4g64
    as long as its a 2000-2005 mitsu eclipse. yes. im pretty surprised someone dug up my old list of parts i made.
    for your list dont forget the evo transmission bolts up to are block as well lol after some cutting
    04-29-2009
    Holyoke,Massachusettes
    3,600
    Is there a parts list for a v6?
    FreakyDeaky
    2kG 6g72/74 5 speed
