Thread: hi, I have a '97 Galant ES and I want some info on smal mods
Page 3 of 3 FirstFirst 123
Showing results 41 to 49 of 49
  1. #41
    roman
    ok well after talking to my friend this is waht I just bought:
    http://cgi.ebay.com/ebaymotors/ws/eBayISAP...DME:B:EOAB:MT:6
    now I will need to get a pipe and make it a CAI ........... I am kind of curious if anyone has ever flooded their CAI? is that a big of a problem?
    I looked in the engine bay and the best spot seems to be right under the battery ....... thanks
  2. #42
    you still need a MAS adaptor
    no flooking of my CAI. ummmm you will hafta take out all the factory airbox even the duct piece next to the battery, then move the battery all the way over. i took out my battery tray also and made a mounting bracket to hold the filter up
  3. #43
    roman
    Quote Originally Posted by seth
    yes and the piping ........... guess I will wait for the filter to come in and then blast u guys with questions
    and yes I will take out the air box ..... and move battery where?
  4. #44
    well once you get all of the air box and that ducting piece out you will see. just move it all the way over towards the passenger fender. you probably will have to take out the battery tray too. but you dont need that.
  5. #45
    BEAST
    Wow I am surprised this post went so long. Aren't we nice . Usually we just tell ya to search and ask if you have any other quesitons.
  6. #46
    San Antonio, Tex-Mex
    1,413
    Quote Originally Posted by BEAST
    LOL That's why it's a sticky for now
    <-Check it out Maz
    My 7g
  7. #47
    roman
    Quote Originally Posted by 2True
    LOL
    k I figured on how to make tha CAi and I will do it via that tutorial with pics ........ once I get all the components in
    and I figured on exhaust too ..... now I have a choice to drop the car or get rims? any ideas?
  8. #48
    TurboGalant
    for your lights
    try xtremewhite.com
    search for mitsubishi
    it will list out all the mitsubishi cars and models
    the list will brake it down to each light bulb
    click on the light bulb you want to replace, and it will list out different bulbs by different manufacturers
    If you go for brighter head lights (higher wattage than stock), you will need a heavy duty wire harness, which they carry (search under harness) for like $25/pair. You can get that cheaper elsewhere, not sure where exactly, it was on a previous post. But you will burn out lights or fry stock harnesses without heavy duty ones.
    Good luck.
  9. #49
    jay25
    <div class='quotetop'>QUOTE(roman)</div><div class='quotemain'>ok well after talking to my friend this is waht I just bought:
    I looked in the engine bay and the best spot seems to be right under the battery ....... thanks </div>
    there is a cure for this problem, flooding your CAI filter, AEM makes a Bypass, if your CAI filter gest soaked with water not to worry the bypass will open up and breath air vice your filter thats soaked. My SCer CAI filter gets soaked all the time but knock on wood I never had any problems.
