Originally Posted by
Reelax
watch out for the rub on the damper. my 19x8.5 VOLKS (+48mm) have touched my rear dampers (TEIN SS-P) on full compression when my rear was not camber corrected. it is VERY tight back there. 19x9.5 +42 (actually 6.6mm closer to the damper) may fit when static but remember the suspension arcs in the rear during travel... the lower you go and the more negative camber the more chance for the inside of the rim to cut the damper; alternatively, camber corrected, it will be very hard to fit those wheels under the fender... remember, my fenders are not just rolled, they are CUT out and i only have about a pinkie clearance to the lip on compression (2.5"-2.75" drop in the rear).
