Thread: Audio questions
Showing results 1 to 6 of 6
    07-13-2005
    * Upstate NY *
    1,289
    Audio questions
    Ok. I searched and found some useful info. I have 2 RE audio 12inch subs. From what ive read, i should use a sealed box because they are pretty much an all around enclosure (theyre good at all frequencies). My question is what kind of amps should i be looking for? Heres the specs of my subs
    RE series
    Electrical Q Value -Qes: 0.42
    Mechanical Q Value -Qms: 4.27
    Total Speaker Q Value -Qts: 0.38
    Free Air Resonance -Fs: 20.0 Hz
    Equivalent Compliance -Vas: 182 liters
    One-Way, Linear Excursion -Xmax: 12 mm
    Efficiency -SPL 1W/1m: 87.3 dB SPL
    Effective Piston Area -Sd: 500 cm^2
    DC Resistance -Re: 3.2 ohm
    Nominal Impedance -Znom: Dual 4 ohm
    Thermal Power Handling -Pe: 175 W
    Force Factor -Bl: 15.4
    These subs handle 250/175 [PEAK/RMS]. Im not looking for concrete breaking bass. Im just want something that sounds sweet and can be heard by people outside my car.
    Heres my headunit too if it helps...
    RMS Power Output 18 watts
    Peak Output 50 watts
    RMS Power Bandwidth 20-20kHz
    Preamp Outputs 3 pair
    Sub Preamp Outputs Yes
    Preamp Voltage 4 volts
    Thanks.
    Experienced TGC Member Divinity's Avatar
    05-01-2007
    Jacksonville, FL
    1,281
    The amp you get should match the rms of your subs. So 175rms subs... so... aroun 175rms running on a 2channel in my opinion
    ~Lady Driven~
    07-13-2005
    * Upstate NY *
    1,289
    Quote Originally Posted by Divinity
    Alright thanks. I just wanted to know what i should look for as compared to walking into an audio store and getting sold some amp i dont need.
    09-10-2003
    Charlotte, NC
    4,463
    to run it better, get a mono amp thats a true 400 watts and 1 ohm stable, something of a quality name like Hifonics or Orion, something high end.
    Then wire it like so:
    07-13-2005
    * Upstate NY *
    1,289
    Quote Originally Posted by Serstylz2
    Thanks. Ima look into all those suggestions. But i wont be doing the wiring myself
    09-10-2003
    Charlotte, NC
    4,463
    its really not hard at all... but if u can pay someone to do it then it'll save hassle
