Originally Posted by
WarmAndSCSI
Why would you wanting yo make your car "go" when it's cold??? :?
Always let your oil come up to operating temperature before giving your car over 1/4 throttle or letting it rev above 3000 RPM.
i let it warm up for 5-7 min before i leave in the morning. it only does it if the engine sits fro over 5 hours
seth98esT
The plugs look like the car has been running lean. What all have you replaced in the ignition system? Have you tried any fuel injector cleaners? Replaced the fuel filter?
And no check engine lights on?
no check engine lights. fuel filter was changed 1 month ago. the rest is stock. the car only has 88k on the odo. i just hit 88k yesterday
the one side of the insulator is white like it came with the other is black. the middle electrode thing has been worn down. these plugs have maybe 5k probably less
if i pull out the other ngks i bet they are the same way now. i put the new ones in 2 weeks ago. everytime i change the plugs it stops doing it for that day.
to clarify on the idele issue the first 90 seconds of starting the car tries to stall. the ecu revs it a tad bit more for a couple second then tries to go to normal and tries to die again. after 2 min it idles fine. until i pull off. the first time i pull off it tries to die no matter how much gas i give it. the engine sounds like it's gargaling and resumes like normal.
ever since the clutch failed the car has pulled like shit
my ecu is retarded, took 3 weeks for it to throw the code for the rear o2 sensor. even the mitsubishi techs said it was supposed to throw it right away. even when the were "communicating" with the ecu it said everything was ok.
i'm about to sell the POS......... not really but close
