Thread: N/A Max Power
Page 4 of 6 FirstFirst 123456 LastLast
Showing results 61 to 80 of 108
  1. #61
    WarmAndSCSI
    Quote Originally Posted by 6G72gearhead
    If you can make the motor sustain revs of about 8k you might reach the airflow required to make 100 hp per liter, in this case 240 at the crank. A small displacement motor in a car that weighs over 2k lbs is just not worth doing. If you want an n/a car go with a V6, and even then your just trying to keep up with Evo's and STI's. Of course an 8G V6 optioned right weighs less than either of the afformentioned cars, so 300 crank hp with a lighter car is going to go faster. Then you can add some nitrous and really have fun.
    Like I said before, 8000 RPM is not safe on any 4G64 IMO. The stock rev limiter is set low for a reason. It's a shame really, but rod ratio is a bitch.
  2. #62
    07-16-2006
    Cocoa, Florida
    791
    i know im gonna rev liek a mother, but i probably wont make any power, im gonna put in eagle rods
  3. #63
    WarmAndSCSI
    Quote Originally Posted by duh2150
    How long did I spend explaining to you why this is a stupid idea? When will you learn to listen?
    Have fun with a hole in your block.
  4. #64
    08-08-2004
    Las Vegas
    2,099
    AMS and a few others recommends a rev limit of 8500 for their 2.4l kits this is do to the rod ratio being changed i think they use a 156mm rod vs the 150mm stock...
    here is some info on a 2.4l
    block: 4g64
    bore: 86.5mm (stock)
    stroke: 100mm (stroke is dictated by crank)
    deck height: 6mm
    cross sectional area of piston: ~5877mm^2
    overall displacement: ~2.35L
    rod length: 150mm (most of the time)
    rod/stroke ratio: 1.5:1
    piston speed:
    100mm stroke at 7200rpm is 24.0 m/s
    100mm stroke at 7500rpm is 25.0 m/s
    100mm stroke at 7800rpm is 26.0 m/s
    you most likely dont want to go over 26m/s without some custom hardware
  5. #65
    when you start adding 200 hp to a car that was only meant to handle 100 hp, you start breaking other things like axles, trannys, etc.
  6. #66
    07-16-2006
    Cocoa, Florida
    791
    lol im fing with you lol i knew you were going to say something
  7. #67
    10-24-2003
    1,432
    Or since the platform has had a 200 hp V6 in it there is a good chance that alot of the components are designed to handle close to that hp figure.
    www.gooichimotorsports.com
  8. #68
    WarmAndSCSI
    You're not going to break shit @ 300 WHP unless you do something ignorant or beat on your car. The F4A42 is only slightly weaker than the F4A51 and the axles are the same.
  9. #69
    anyone ever bored out a 64? if so how much over can you go safely?
  10. #70
    08-08-2004
    Las Vegas
    2,099
    i'm at 87.5mm on my build
  11. #71
    07-16-2006
    Cocoa, Florida
    791
    thast becasue you honed your engine
  12. #72
  13. #73
    08-08-2004
    Las Vegas
    2,099
    wiseco high compression 11.5:1
  14. #74
    WarmAndSCSI
    Overbore != hone
  15. #75
    07-16-2006
    Cocoa, Florida
    791
    same thing lol stop correcting me if your boring it out your honing it also, your not gonig to bore out the cylinder into a egg shape lol, im gonna make square pistons one day lol
  16. #76
    Come on, now you just sound like an asshole....
    222whp/250wtq
  17. #77
    07-16-2006
    Cocoa, Florida
    791
    lol no im not think about how much more area you get with squares then with circles
  18. #78
    WarmAndSCSI
    LOL, have fun making a square piston "ring."
    Put down the pipe, man.
  19. #79
    07-16-2006
    Cocoa, Florida
    791
    lol yeah how am i gona figure that math out 0.0 to great for my mind!! :shock:
  20. #80
    10-24-2003
    1,432
    To get the greatest efficiency out of a combustion such as what happens to make your engine run, it has been proven time and time again that round is the most efficient.
