Thread: Can you help me match the Model, Trim, and Engine?
Showing results 1 to 11 of 11
    Hi, guys! I am a new member on the board and I own a automotive performance company but, I'm not here to SPAM. I am working on adding some new parts for your cars but, I need more info on which engines were offered in which years and trims. I tried wikipedia but, the info on the older models is really lacking. Could you guys help me out?
    This is what I have so far...
    (The 04- model is done I believe. Please correct me if I'm wrong.)
    Galant 84-89
    1.6L I4 SOHC? 8V? 4G32?
    1.8L I4 SOHC? 8V? Turbo Diesel 4G37?
    2.0L I4 Astron 4G52?
    3.0L V6 6G72
    Galant 89-93
    1.8L I4 DOHC? or SOHC? 8V? 4G37?
    2.0L I4 102hp SOHC? 4G63?
    2.0L I4 135hp DOHC? 4G63?
    2.0L I4 Turbo DOHC 4G63T
    Galant 94-98
    1.8L V6 SOHC 24V 6A11
    2.0L I4 4G63?
    2.4L I4 4G64
    2.0L V6 SOHC 24V 6A12
    2.5L V6 SOHC 24V 6A13
    VX-R (non-US) 2.0L V6 DOHC 24V Twin Turbo 6A12TT
    Galant 99-03
    1.8L I4 4G93 GDI
    2.0L I4
    2.4L I4 4G64
    2.5L V6 SOHC 24V Twin Turbo 6A13TT
    3.0L V6 6G72
    Galant 04-
    DE/ES 2.4L I4 SOHC 16V MIVEC 4G69
    Ralliart 3.8L V6 SOHC 24V MIVEC 6G75
    Re: Can you help me match the Model, Trim, and Engine?
    Quote Originally Posted by XLevel
    Galant 84-89 1.6L I4 SOHC? 8V? 4G32?
    3.0L V6 6G72
    Galant 89-93 1.6L I4 SOHC? 8V? 4G32?
    Galant 94-98 1.8L V6 SOHC 24V 6A11
    2.0L I4 4G63?
    2.4L I4 4G64
    Galant 99-03 1.8L I4 4G93 GDI
    2.0L I4
    2.4L I4 4G64
    3.0L V6 6G72
    Galant 04- DE/ES 2.4L I4 SOHC 16V MIVEC 4G69
    I think if you listed as is, people could help you out more instead of putting it in different generation forums.
    Love,
    Matt
    Galant 89-93
    This really aren't al the versions.....
    You still have a:
    2.0L I4 144HP DOHC 4G63 (wich i have)
    1.8 versions varied from 75 (diesel) to 93 HP and where all OHC's (SOHC), as far as i know.
    2.0 L versions varied from 107 to 144HP, and only the 16Valve version was DOHC, as far as i know.
    But searching on the internet, will give you all the answers. This are the numbers i have in my head, they could be a bit wrong(a few HP's ), but nothing seriously. Send me an PM, when you need sites for your "research".
    the generation years are going to be different for each country... for example, 8th gen USDM was 99-03 but 8th gen JDM is 96-03(4?). almost all generations are staggered this way accross the globe. depending on what country, the years will not be the same for the same body style.
    08-15-2006
    Perth Amboy, NJ
    1,558
    Mitsubishi Galant - 8G
    DE (which i have), ES, LS, & GTZ
    http://consumerguideauto.howstuffwor...shi-galant.htm
    run1206's Rear Disc Tutorial
    i really dont think you will need to sell parts for 5th generation and before...
    Member fuel's Avatar
    01-24-2007
    Hamilton, New Zealand
    281
    because I'm bored I'll help match models for the JDM and NZ/Aus spec Galants
    5th Gen Galant 1983 until 1988 (Japan and NZ, US until 1990)
    E11A 1.6L I4 SOHC 4G32 GL or GLS model
    E12A 1.8L I4 SOHC 4G37 GLS or GLX model
    E17A 1.8L I4 SOHC Diesel Turbo 4D65
    E15A 2.0L I4 SOHC 4G63 (available carburettored, MPI and ECI-Turbo)
    E18A 3.0L V6 SOHC 6G72 Duke, V3000, Galant Sigma model
    6th Gen Galant 1987 until 1992 (some markets until 1993)
    E31A 1.6L I4 SOHC 4G32 G, GE, GL
    E32A 1.8L I4 SOHC 4G37 MF, GF, GLX
    E34A 1.8L I4 SOHC Diesel Turbo 4D65 MF-D, GF-D
    E33A 2.0L I4 DOHC 4G63 MX, VX, VZ, VX-S, VZ-S, SEi, GTi-16V
    E33A 2.0L I4 SOHC 4G63 Super Saloon
    E35A 1.8L I4 DOHC 4G67 Viento, MS
    E37A 1.8L I4 SOHC 4G37 MPI 4WD
    E38A 2.0L I4 DOHC Turbo 'RS' VR-4 with no 4WS
    E39A 2.0L I4 DOHC Turbo VR-4 with 4WS
    7th Gen Galant (1992 until 1996 Japan and NZ, 1993 until 1998 Australia, Europe and Japan)
    JDM models:
    E52A 1.8L I4 SOHC or DOHC 4G93 GF, MF, EXE
    E53A 1.8L V6 SOHC 24V 6A11 Viento, EXE, MU
    E54A 2.0L V6 SOHC 24V 6A12 MX
    E54A 2.0L V6 DOHC 24V 6A12 VX, MX-D
    E54A 2.0L V6 DOHC 24V 6A12 MIVEC VX-R, Visage-R, Super Touring R
    E57A 2.0L I4 SOHC Turbo Diesel 4D68 MU-D, GF-D
    E74A 2.0L V6 DOHC 24V 6A12TT twin turbo VR-4 without 4WS
    E84A 2.0L V6 DOHC 24V 6A12TT twin turbo VR-4 with 4WS
    Aus/NZ models:
    GL 1.8L 4G93 SOHC carb
    GLX, Super Saloon, SEi, GSR 2.0L 4G63 SOHC MPI
    GTi 2.0L V6 DOHC 6A12
    8th Gen Galant (Japan and NZ 1996 until 2006, US 1999 until 2004)
    EA1A 1.8L I4 4G93 GDI base model Japanese loser cruiser
    EA2A 2.0L I4 4G63 SOHC Europe and NZ model only
    EA3A 2.4L I4 4G64 SOHC for US, DOHC GDI for Japan
    2.5L V6 SOHC 24V 6A13 VR, V6-24 models
    2.5L V6 SOHC 24V Twin Turbo 6A13TT VR-4
    3.0L V6 6G72 US spec only, has macpherson strut suspension instead of multilink
    Galant 04-
    I'm going to be making a website with all the different Galant models if anyone wants to contribute something. I specifically want information about the Euro and US spec Galants as I have more than enough info about the Jap spec Galants
    NEWBIE
    06-28-2005
    Appleton, WI was Madison..
    15
    For the 6G Galant.. for USDM markets
    There was..
    2.0L 4 cylinder
    8-valve SOHC (89-92) anything besides GS, GSR, GS-x & VR-4 (stock & LS models)
    16-valve DOHC N/A found in Galant GS, GSR, GS-x
    16-valve DOHC TURBO Galant VR-4
    16-valve SOHC (93 model year ONLY ... S, ES, LS)
    <a href='http://imageshack.us' target='_blank'></a>
    '92 Galant LS
    '92 Galant VR-4
    '92 Galant GSR
    '93 Galant S (DOHC swapped DD)
    Quote Originally Posted by fuel View Post
    iunno if you ever made a website but you can add info to the wiki, its easy... click link in my sig..
    6a13
    there's one missed:
    EA6A 4D68 2.0L I4 SOHC Turbo diesel
    and 2.5L V6 SOHC 24V 6A13 V6-24 is EA5A and 6a13TT VR-4 are EC5A (galant), EC5W (legnum) and it should be DOHC engine
    JDM models:
    Aus/NZ models:
    Galant 04-
    8th gen galants in the us stops in 2003
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
