Thread: alignment??? does it work??
Showing results 1 to 8 of 8
    hey everyone i was just wondering if alignment really works because i lowered my car and i noticed that my tires was getting worn out in the front... some people told me it works other said i need a camber kit... but i dont know because they dont drive a galant thanks
    uhhhh...... Whats a 9g???
    12-17-2002
    Sherman Oaks, California
    4,304
    u might need a camber kit. at worst, go in for an alignment, and they can always adjust your toe on the fly right there. that might releave all the wear you're getting on your front tires. when you go in for hte alignment, the mechanics will tell you what you can do that they couldn't. it will definatly help the wear problem though.
    http://socallifestyle.com/
    1994 Galant GS 5spd
    San Antonio, Tex-Mex
    1,413
    How far did you drop it?
    <-Check it out Maz
    My 7g
    ummm not that much about 1.5 in the front maybe more n 1 inch in the back, but i can still put in umm lyke 2 fingers between the fender and the tires
    nitegsrider
    I think that i def need at least a 4 wheel alignment
    1,413
    Quote Originally Posted by krazienluv10
    If that's all you dropped then you definately just need an alignment. The tire shops can actually fix camber up to like .2 degrees or something. That's all you should need, good luck :thumbsup:
    <-Check it out Maz
    My 7g
    thankx
    jay25
    I know I am late but Ill just get my wife to take her car in for an alignment.
