Thread: VIP-style Galant
Page 9 of 10 FirstFirst ... 5678910 LastLast
Showing results 161 to 180 of 194
  1. #161
    05-01-2008
    Manitoba
    1,589
    Quote Originally Posted by VIPtint View Post
    15mm spacer will get it pretty flush. just gotta find some for cheap
    I wonder where do you have to put the spacers?
    Tuned 2013 Evolution X GSR PB
  2. #162
    05-01-2008
    Manitoba
    1,589
    you may also want to have RRE relocate the spring perch if possible so that you can run more coils and still be slammed. looking at your pics, the front is only sitting a little lower than mine... i am running coilovers which include shortened body dampers, but i'm also running a much biger tire... NITTO INVO 235/35r19. i probably can only lower 1/2" more before i run out of threads on the adjustable perches. if you don't have enough room for springs, it might just have to be bags, conventional coils, even full coilovers w/ short body dampers, can only go so low. the EASY STREET kit is a cheaper alternative to going full blown AIR RUNNER.
    here's some pics taht show my front clearance for reference:
    o yeah and you definitely need to roll/fold/cut the rear fenders so that you can push the wheel out even more in the rear... the rear flushness is the key in what you are going for. i think from looking at the pics, that you can go w/ a 15mm-20mm spacer back there if you run enough negative camber and cut/fold the rear fender lips out (since the 205 tire is giving you plenty of clearance). thank god our rear wheels don't need to steer, but mitsu didn't have to make the front wells THAT much bigger!
    Is the EGR visor colored match the car?
  3. #163
    Quote Originally Posted by Galante View Post
    yes, on both sides and clear coated. twice... this is the second color the car has been painted.
  4. #164
    05-01-2008
    Manitoba
    1,589
    Nice man. I'm gonna have to get mine painted too.
  5. #165
    I got huge problems turning my wheels when standing downhill or turn fast when braking. I feel sorry for my tires
  6. #166
    ok rear fitment w/ 8mm spacer
    OOOH NASTY
  7. #167
    Nice, I'm liking it.
  8. #168
    01-24-2005
    DFW/Stillwater
    2,752
    u should make a separate build thread for this
  9. #169
    i should huh?
  10. #170
    yep, you should
  11. #171
  12. #172
    looking good bro! if those rims on the rear are wider it would be SICK but still looks tight.
  13. #173
    yup. if you look at it from right behind the car you can tell they are skinny. only part that sux. but hey im goin cheap on this ride
  14. #174
    ok all four corners dropped and wheels on
  15. #175
    [/URL]
    Damn ,that looks fantastic, what did you use to drop it so low?
  16. #176
    hmm.. interesting
  17. #177
    nokcy21 hooked me up with some cut progress springs that he had. the ride isnt that bad at all. but i have only about an inch of travel on the fronts so it bottoms out pretty easily. i cut the bump stop down to just the last rib so it doesnt hit that bad
  18. #178
    that think looks bad ass!! Now just the cancer paint has to go
    00 Galant ES Turbo/5-Speed
    13 GTR
  19. #179
    No rubbing?
    BTW, is that an R34 skyline in the background of the 3rd picture from the top?
  20. #180
    heres the problem though. at this height the toe in is massive and i dont think there is enough adjustability for the rear. the front can be corrected no problems but idk about the rear.
