Rear upper strut bar won't work unless you don't want your back seat. Lower tie bars should work but your best bet is to get a rear sway bar setup from the eclipse. You might also want to get the prothane bushing kit if you don't have it already. The ralliart 4pt underbrace that john(stunr) has is pretty much impossible to find unless you know someone like trigger who can find one for you but it will be expensive to have imported.
