Thread: flashing head lights
Showing results 1 to 13 of 13
    This is so weird..
    Last nite the car was parked as usual.. I came this morning to start up and as soon I turned on the ignition, the head lights were flashing! Like on.. off.. on.. off.. on.. off..
    I was like :shock: what!!!!!!!!!!
    Anyone know wth was that about???????????
    Experienced TGC Member Divinity's Avatar
    05-01-2007
    Jacksonville, FL
    1,281
    You might have a loose ground somewhere, or a melted bulb harness or ground. That used to happen a lot with my other car.
    ~Lady Driven~
    07-31-2002
    Tallahassee, FL (FSU)
    1,324
    Re: flashing head lights
    Quote Originally Posted by haleemul
    This is so weird..
    maybe your car thinks its teh po-po?
    -Chris
    07-31-2002
    Baltimore, MD
    2,848
    Or maybe you set off the alarm??
    Chip
    (Paint Code: Porsche LC9Z)
    my bulb connecters were shitty like that to, they melted and it did that.
    Yah but the funny thing is.. i let it run after ignition for 5mins.. then turned off.. and waited for a minute.. then restarted and it was fine :S.. ! ! !
    What is up with that lol..............
    factory alarm was going off
    also a little thing should flash on your cluster. looks like a key
    2011 Camry- 202 miles- just picked up 9/10/10
    2008 Pontiac G6- 26,065 miles- traded in
    1999 Galant ES- 91,846 miles- long gone
    07-31-2002
    Baltimore, MD
    2,848
    Quote Originally Posted by QnzMostWanted
    I think I said that 3 posts up
    Welcome home Denver!!!
    Chip
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    wtf do i got an alarm? i got a de lol
    <a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&amp;current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
    Quote Originally Posted by duh2150
    probably not.
    WarmAndSCSI
    Stop huffing glue.
    projectGTZ
    I had the same problem. Check the under hood anti-theft sensor. It is the black button looking switch about half way down the drivers side engine compartment against the side where the upper part of the fender mounts, easy to find and by itself. The bracket that supports it is poorly engineered and flimsy. Try bending it up a tad and see if that resolves it.
