Thread: kia valve cover problem?
Showing results 1 to 20 of 28
    07-16-2006
    Cocoa, Florida
    791
    well i put my new valve cover on the kai head i got in my room all the bolts line up perfectly but i saw this
    a gap between the hte sensor housing and the valve cover? is thewre something missing? or can i just put in the gap or something?
    Experienced TGC Member Divinity's Avatar
    05-01-2007
    Jacksonville, FL
    1,281
    Don't you dare drill any holes in that thing lol
    ~Lady Driven~
    12-27-2005
    Charleston SC
    1,520
    cant tell from the pics.. so im gonna ask.... is the gasket still in the vc?
    01-07-2006
    707
    Hmmm, I don't see a gasket in there, so maybe when you put one on it might seal up the gap
    12-27-2005
    Charleston SC
    1,520
    Quote Originally Posted by DNSerrano
    Exactly what im thinking myself.
    07-16-2006
    Cocoa, Florida
    791
    the gasket is on it its on the bottom rim of the valve cover, thats what i thought but if i move the cover that direction none of the bolts will lines up
    01-07-2006
    707
    The most drastic thing would be to put some, I mean a small amount some, of liquid gasket on that corner then, UNLESS they sell some kind of a seal for that part of the head
    07-16-2006
    Cocoa, Florida
    791
    yeah thast what i dont understand, the head i took it off of didnt even have that gap, or did it?
    07-16-2006
    Cocoa, Florida
    791
    underrated could you take me a pic of your piece?
    07-16-2006
    Cocoa, Florida
    791
    theres a piece that lines up but its like 2 or 3 mm off the block on the other side, il ltry and upload later, is it possible to have the wrong valve cover? the botls lien up and everything its jsut the side for some wierd reason?, still looking for help!
    05-01-2007
    Jacksonville, FL
    1,281
    Just wondering.... have you put the bolts back in it yet and tightened the to spec?
    ~Lady Driven~
    12-27-2005
    Charleston SC
    1,520
    my valve cover has almost the same gap as that all the way around.... the valve cover gasket makes it that way.... if the whole valve cover is sitting flush on top of the head.. im pretty sure youve over torqued them.. the bolts are just a little more than hand tight.......
    WarmAndSCSI
    Quote Originally Posted by Shadow19
    He hasn't even torqued anything yet...
    07-16-2006
    Cocoa, Florida
    791
    its not about torqued down its say to big of a gap even if they were bolted down i could take off the gasket and bolted it down and itll be closer but itll stil lnot even touch loo kat the pic the gasket wont touch that eve if it was torqued or not becasue it comes out, the gasket goes in the under rim of the valve cover not the outer rim lol
    01-07-2006
    707
    Hmm, I replied to your PM in Galants.org but I will post it up here, the head is from a 2002, the 3rd Gen Hyundai Sonata that makes 149hp. The one with the projectors
    07-16-2006
    Cocoa, Florida
    791
    yeah, maby i got a way newer valve cover, or they did something in the other years or somthing, when i looked at the engine, i was most positive that, it was the right engine, looks just like it and everything, so wtf lol, i ot my bro to go over there and recheck the year
    07-16-2006
    Cocoa, Florida
    791
    valve cover off kia optima made in 2004 sold in 2005, but looks like a 2006, wtf,, but vin number says its a 2001
    07-16-2006
    Cocoa, Florida
    791
    im so lost im gonan loo kat it tomarrow hopefully again
    08-04-2003
    NY
    4,344
    Ok so looking at that pic you posted, I dont think their should be a problem. As long as the valve cover gasket seals against that surface. On my EVO head I have a gap too, granted its not that large, but its still a gap. I did some research and the sealant locations for liquid gasket on the valve cover are the same as the EVO, on both sides of the last cam cap on the T belt side and on the semi-circular block off plate at the end of the intake cam. If you need it, here is a link to the Kia Factory Service manual online, free. Dont be scurred about the language install thing, just say no, the manual is in english.
    http://58.87.51.38/kme_viewer/
    99' Galant ES
    4G64/63T
    AEM EMS
    07-16-2006
    Cocoa, Florida
    791
    i got a like 2 mm or 3mm gap over the cams at thend left my bro found a piece of liek rubber that goes over the right side, im supsoeing i havnt seen it yet, but i might have ot go there and take the gears off and get the left side maby theresa a half moon piece?
