those are called compression arms,
and no, no one makes a kit for those arms. and if you watch what those arms so, while someone turns the steering wheel, you will understand why a harder inflexible compound cannot be used there.
no worries though, that bushing doesn't in any way effect lateral stability(as far as suspension flexation is concerned)
but you should still get the prothane kit.
its the best thing you ever did for your suspension
