Thread: 2.4l dohc N/A build
Showing results 21 to 40 of 41
    ^ LOL, under 12psi i brake 200whp. Good Luck!
    08-08-2004
    Las Vegas
    2,099
    Id be curious to see gains with the ITBs. Going to dyno it with the stock plenum, then with ITBs?
    yah its gonna go like this... get car running with stock intake manifold tune it to pass smog lol... retune it for as much power as possible after smog, dyno it... then throw on the itb's and retune the dyno it againif im not happy with the results then the direct port setup goes on and its going to be a 100 shot dry kit, i may need bigger injectors but we will see.
    the fuel injectors calculator i used said the 450's are good to 230hp @ 80% iirc
    i dont know what my goal is i just think it would be interesting to see what the car does with this build... my final turbo setup made 252whp it would be great to make that with this setup but that may be wishful thinking lol
    Random guesstimate, 243whp 254ftlbs with the ITBs :P
    252 NA whp has got to feel much more fierce then 252 FI whp. Going to have a sweet power curve with this setup :)
    07-20-2003
    Orlando, FL
    3,169
    That is amaing work Brandon..its impressive to see what you have done. I hoping you make some nice power with a built N/A. Like what Seth said...making power on N/A that you did on F/I is going to be nasty. I would love to hear that motor when you get the ITB's on. ITB's sound soo sexy...its such a sweet sound.
    i don't seem him making the torque with itb's
    but definatly the hp
    WarmAndSCSI
    I dunno about a sweet power curve... he does have 272/272 cams after all. Lots of power? Yes. Good power band? No. I really think the 4G64 is going to run out of revs before you reach the full potential of those cams.
    Brandon, do you have any plans to destroke the 4G64 so you can at least rev it out a little more before you start reaching dangerous piston velocities?
    It's also crazy that you're using head studs on an N/A engine Had some extra money to spend? I don't know about the 4G64's head bolts, but the huge ass ones on the 6G72 will take more than 25 PSI (600-700 WHP) without any head lift.
    09-10-2003
    Charlotte, NC
    4,463
    Quote Originally Posted by Serstylz2
    ^^ how are you gonna be NA, didn't you just pick up all the turbo parts to replace your S/C
    Yep, wasn't talking bout my car. Read it again
    There's another silver Galant sitting at my house that needs some TLC that happens to belong to a friend of mine that was deployed to Iraq. Connect the dots
    Ahhh I understand now, I was once blind but now I seeeee
    08-08-2004
    Las Vegas
    2,099
    yah i have a evo crank sitting in my storage too the 88mm crank would make the 4g64 a 2.1 and with the 88mm bore i'd have a perfectly square engine i was reading on evom and some of the people with destroked 4g64's take the revs up to 9-10k :shock: i was gonna do it but i was worried about the transmission
    my rev limit is going to be 8k i'll probably shift at 7.5, and those 272 cams will not be put to their limit in n/a form with a that im interested to see what the power curve looks like on the dyno... the 2.4 should put out good torque and the itb's should help with the top end so im thinking the dyno sheet will show more hp then tq unlike the the usual graphs where torque is higher then hp
    i really dont know what to expect i'f im disappointed with the numbers the evo crank is going in and a big shot of nitrous along with it
    i cant be too mad at the build i got a lot of stuff free or at a highly discounted price... and the machine work was done by a friends dad since he owns a shop. i got headstuds cheap i'm just gonna use them because they are reusable just incase i have to take the head off again for any reason
    08-04-2003
    NY
    4,344
    Quote Originally Posted by underated
    I would mess with the cams and nitrous shot before I even considered going 2.1 and revving high. I can tell you that my tranny hated 9,000RPMs, after about 2500 miles of random high RPM shifts, the synchros were starting to go.
    99' Galant ES
    4G64/63T
    AEM EMS
    08-08-2004
    Las Vegas
    2,099
    Thanks thats what i was afraid of whats your rev limit now?
    WarmAndSCSI
    Mad props on getting some of that stuff for so cheap/free... the DOHC swap makes finding head components a lot easier, too. 8)
    08-08-2004
    Las Vegas
    2,099
    yah i couldnt believe that rpw wants 600 for one cam for the sohc head i bought the whole sonata engine for 400
    you could do the whole dohc swap for around 600
    08-08-2004
    Las Vegas
    2,099
    double post
    WarmAndSCSI
    double post
    Double post 30 minutes later?
    08-04-2003
    NY
    4,344
    7500, I could take it to 8000, but I was advised that repeated 8000 pulls would wear/stress the internals significantly more.
    99' Galant ES
    4G64/63T
    AEM EMS
    WarmAndSCSI
    Yeah, the rod ratio of the 4G64 isn't too great... you're putting lot of stress on the cylinder walls at 8000 RPM. Not to mention the piston velocity alone is staggering with a 100 mm stroke.
    08-08-2004
    Las Vegas
    2,099
    i found this on evom i would just need to find the longer rods
    4g64 88mm crank DEstroker 2.1
    4g64 2.1 specifications
    block: 4G64
    bore: 86.5mm
    stroke: 88mm
    deck height: 6mm
    piston cross sectional area: ~5877mm^2
    overall displacement: 2.068544 L
    rod length: 162mm (at least for magnus's)
    rod/stroke ratio: 1.84:1 (at least for magnus's)
    piston speed:
    88mm stroke at 8000rpm is 23.467 m/s
    88mm stroke at 8500rpm is 24.93 m/s
    88mm stroke at 9000rpm is 26.4 m/s
    08-04-2003
    NY
    4,344
    Slowboy racing sells Manley rods that are 162mm for this setup. All of what you just posted is for the 2.1 destroker. Like I said, it will work, and have better rod ratio's, but I would fear the tranny.
    99' Galant ES
    4G64/63T
    AEM EMS
  19. #39
    WarmAndSCSI
    I'm glad the 6G72 has what's essentially an Evo VIII 5-speed in it.
    F5M51 versus W5M51. Internal components are all the same.
  20. #40
    TGC Regular djflex167's Avatar
    07-21-2007
    Manhattan, New York
    709
    man that engine looks poppin!! great job u r doing!!
