like horizontally? (left to right) ?or vertically (front to back)? :arrow: :smt041Originally Posted by WarmAndSCSI
that still does not answer my question what does everyone gap there plugs at for the 2.4 l ?
Either way will throw off the timing if you think about it... if the mark is closer to the cog, it's going to appear either advanced or retarded depending on which side the timing notch is on. I'd expect it would be bent up or down... the most you need to do is make sure the lip where the timing notch is cut out is level with the rest of the engine.Originally Posted by silversurfer
i replaced the engine mount and still vibrating now it seems like its rougher in gear
