Thread: Front Sway bar
Showing results 1 to 5 of 5
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    Front Sway bar
    Finally found what was making the noise in my suspension - the sway bar bushings are worn out. I unbolted the end links and that thing was wobbling as hell, so Im going for aftermarket and I was wondering if anyone knew the size of the sway bar. I did little research and found that 2G eclipses come with three sizes - 18mm, 19mm and 20mm, but didnt find anything about my 94 Galant. any recommendations?
    Build Thread
    WarmAndSCSI
    Don't up-size the front swaybar unless you want more understeer.
    12-17-2004
    Louisville, KY
    4,328
    Quote Originally Posted by WarmAndSCSI
    i think he just wants to replace the bushings, but doesn't know what size the factory galant front bar is.
    he wants to know what size bushings to buy
    i'm pretty sure its 17mm. but before you go order parts.
    i'd take an open end wrench, and find the size wrench that fits the bar perfectly.
    its what i did to determine the size of my RMDSM bars when it came time to replace the bushings.
    Quote Originally Posted by DOHCstunr
    do you still have the rear mini stock sway bar? I was thinking of bolting up a gst sway bar for a little less understeer.
    1994 gs dohc turbo
    09-20-2007
    Sea Isle city, NJ
    4,098
    OK, front sway bar is 18mm. Just got 19mm and installed it. Big difference.
    Build Thread
