Thread: remote
Showing results 1 to 3 of 3
    remote
    on the stock remote that come with the car is there a code or something else cause i lose my and my friend give me has remote and i am trying to ask you guy to see if all can help me out thank
    4,455
    You have to reprogram the remote. The how to was discussed on here a few times before. If you use the search function I am sure you will find it
    Jason - - cofounder of TGCNY
    2001 Galant ES
    Locate the <?xml:namespace prefix = st1 />Data Port.
    <?xml:namespace prefix = o /> <?xml:namespace prefix = v />
    Insert keys in ignition and leave in the OFF position.
    Make sure there are metal contact pins in terminals 1 and 4 and connect the Data Port terminals 1 and 4 with a suitable jumper wire, leave the jumper wire connected throughout the programming procedure. Make sure you know which terminals are 1 and 4.
    Within 10 seconds after connecting the jumper wire, press the Hazard Switch 6 times. Note: The doors will automatically lock and unlock once at this time indicating that the system is in the programming mode.
    Press the LOCK button on the remote to be registered three times within 10 seconds. Upon successful programming, the door will lock and unlock once.
    Repeat step 5 with up to 4 remotes (including any existing remotes) within one minute. After completing each programming, the doors will lock and unlock once.
    Disconnect the programming wire and remove the keys from the ignition..
