Thread: Dohc ?
Showing results 1 to 10 of 10
    North Bay...NorCal
    2,552
    Dohc ?
    I still have not made up my mind about what to do with my car yet. But this might be a silly question. So I know the 1G DOHC has better air flow, but cosmetically I like the look of the 2G head cover (stupid I know). I was wondering can I get a 1G head and put the 2G head cover on it? Or is that just a newb question. Oh and another question....would there be any real difference in performace, 1G vs 2G without any other mods...i.e. just the head swap? If I remember correctly...no, but just in case
    newbie.............
    the valve cover on the 2g/1g is the same
    just different colors.
    1g: silver with red letters mitsubishi 2000 dohc
    6gvr4: red w/ silver letters mitsubishi dohc
    2g: silver with silver letters mitsubishi 2000 dohc
    7g gs: silver w/ silver letters. mitsubishi dohc
    hyundai: smooth top, black w/ silver letters. dohc 2000
    i lile hyundai' s better. its clean
    i like the clean smooth top of the hyundai. but i hate the font the letters are in.
    as far as headflow:
    the 1g has more flow.
    but
    once the 2g head is ported to match the 1g intake gasket. the 2g head flows more AND makes more power.... through a better entry angle into the cylinder.
    North Bay...NorCal
    2,552
    So then without any porting the best bet...staying as stock as possible anyway, the 1G would be the way to go then. Thanx
    not neccecerily
    untouched.
    the 2g head makes more torque. hands down.
    Depends on how far you are wanting to go with your project. If your staying NA, Id probably stick with an unported 2g head. If your going turbo then 1g head.
    Quote Originally Posted by seth98esT View Post
    or a 7g gs head.....
    i think i know where you can find one
    North Bay...NorCal
    2,552
    yes I know...but I am soo broke right now its not even funny! LOL I saw that shit and was droolin
    08-18-2004
    Charlotte, NC
    1,029
    Four flavours to choose from..
    1G 4g63
    2G 4g63
    4g67
    4g61
    The 1G/2G have combustion chambers at 47cc .
    The 4G67/4G61 have combustion chambers at 43cc.
    The 1G and 4G67 have the same intake ports.
    The 2G and 4G61 have about the same intake ports.
    The 4G67/4G61 heads will increase compression by .4 to .5 points.
    Small intake ports intend to generate more torque than large intake ports,
    larger intake ports intend to generate more top end hp than smaller ports.
    A decent dohc head especially from the 4g67/4g61 can be find as low as 90 bucks on car-parts.
    1994 GS FYI
    DSM/CSM Manuals
