Dual
Im about to order a mtx sledgehammer box with 2 7512 subs in it, but it says single voice coils. Should i get this with single 4 ohm or dual 4 ohm? which will let me wire down to 2 or 1 ohm? My friend has the mtx sledgehammer but he says he got the dual 4 ohm subs and his shit slams so hard, so i dunno. help me out plz
this is wut im gonna order
http://www.electronicsbonanza.com/co...X-SLH-T7512X2D
either one doesn't matter
DVCs are just made to give you more wiring options.
if you go SVC, your choices or wiring are 8 and 2 ohms with 2 subs (depending if it is bridged or 1 sub per channel/amp)
if you go DVC, your options are 4 and 1 with 2 subs (on a mono block amp)
Dual 4ohm. Wire the speakers in series and bridge the amplifier.
Dual 4ohm will be more wiring options but just remember that when you buy and amp your going to have to get one that is 4ohm capable, some of the amps are not capable of running at 4ohm's.
1996 galant s
and if you want a 1 ohm amp, parallel the VCs and bridged the amp
dual coils on a 1 ohm amp = max power :D
What amp are you running? I can throw u a diagram if u give me an amp
rite now i have a kickerzx1000.1 but i think im gonna run the 7500's on a mtx 7801 mono amp which is 800 watts rms at 2 ohms. accordin to crutchfield wiring diagrams, running 2 dual 4 ohm subs gets u 4 ohm load. you get the 2 ohm load with 2 subs with the single voice coils....right? how do i get a 1 ohm load with those subs on the mtx amp?
