are the wheels balanced? are they on there correctly, with the right lug nuts and torqued to spec?
I have a 2002 Mitsubishi Galant 2.4L.
While I’m driving I hear a repeating vibrating noise coming from the rear.
I thought it was one of the rims but they aren’t bent.
I’m thinking the hub or bearing.
Has anyone else had this problem? Or know what the problem is?
how is the tread on your rear tires? i had a bad rear tire and it caused a nasty vibration i was scared to go faster that 50 cuz it wuld get really loud and i wuld feel it in the steering...new tire fixed that
if it gets faster as the car goes faster, its definantly the hub. my car was doing that after filling it up with people one crazy night and it turned out the hub went bad, i replaced it with a used one from my rear disc swap and the whole thing went away
yeah, took them to the shop to get done.
When I first got my '02, it kept making an awful moaning sound in the rear. I loosened and re-tightened the lug nuts, making sure to cross-tighten to the right torque spec, and the noise went away. I guess the mis-tightened/over-tightened lugs were warping the rotor and making it drag on the brake pads. It's been fine ever since.
