Thread: HOW TO: Clear your corners! (now with pics!)
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 43
    Required tools:
    Heat Gun or Blow Dryer (I use a blow dryer) Pair of Gloves 10 Zip Ties (not really necessary if u know what u doing) Silicone Sealant Needle-Nose Pliers Flat blade Screwdriver Phillips Head Screwdriver 10mm Socket Wrench 12mm Socket Wrench (to remove the bumper if u choose)
    Step 1 (u could jack up the car and remove the wheels, but u dont have to) Remove the fender covers (or just bend it back)
    Step 2 using a 10mm with a long extension, remove the bolt that connects the bumper to the fender (it is all the way towards the front of the car, only access is through the fender covers)
    Step 3 Remove the bolt that connects the bumper to the fender right at the wheel well
    Step 4 Remove all clips and bolts under the car that hold the bottom bumper lip
    Step 5 remove Grilles (94/96 - there are 2 screws per grille) (97/98 - there are 3 clips per each grille which have to be removed from the inside)
    Step 6 (94/96) There are 2 10 mm bolts that hold the bumper to the t-bar behind the grilles (97/98) There are 4 bolts on the upper side that hold the top of the bumper to the header bar
    Step 7 there are 4 plastic screw clips that u have to pry up using a flatblade to get the bumper shell off
    step 8 Remove the bumper shell (be careful because ur signal light wires are connected there, either remove them before u take off the bumper shell or leave them on, and there is a clip in the back of the lights that u can remove)
    Step 9 (optional) using a 12mm remove the 4 bolts holding the bumper onto the car (the bolts are located under the highbeam light on the bumper (if u have OEM fogs, u must remove them to take off the bottom bumper bolt))
    Step 10 using a 10mm, remove the bottom 2 bolts of each headlight, the easier one is located by the horns, the harder of the 2 is located behind the bumper which makes taking off the bumper worth while
    Step 11 remove all the bolts holding the tbar/header bar onto the car, there are 3 in each corner, one above the headlight (by the highbeam)
    Step 12 (kinda tricky) the t-bar/headerbar makes a slight L-shaped angle behind the bolt by the highbeam light on the top of the headlight, what u have to do is kinda move the headlight out of the way so u can fit the 10mm to the bolts, there are 2 of them on each side
    Step 13 Remove the T-bar/header bar slowly, cuz u can scratch ur paint at the egdes where the t-bar meets the fenders
    Step 14 there is a main clip for power for the headlights, remove that and the side marker bulbs remove the headlight assembly
    Step 15 Take the headlight assembly, starting with the corner remove the screw (also remove the clips that go around the headlight) and begin to heat ur headlight where the black plastic meets the clear lens (take ur time, do not rush this)
    Step 16 Once the factory silicone is soft use a flat blade and begin to pry the headlight assembly apart. **note: U can pull the entire assembly apart, or u can open it only at the corner, if u pull it all the way off, u just pull the orange piece off, if u just open the corner, once it spreads there is another philips screw u need to remove, once that is out, the small corner lamp assembly will be loose
    Step 17 using ur screw driver break out the orange piece and use ur flatblade to hold it so u can grab it with ur needle nose pliers, Pull the orange piece out, be careful that it doesnt break, if it breaks it'll just take that much longer
    Step 18 Fit the corner lamp assembly back in place and put back the philips screw
    Step 19 re-heat the factory silicone, and Fit the headlight back together, once the silicone begins to dry u will need to just apply pressure to the 2 parts to hold it tight, once it drys, take some fresh silicone and reseal the ENTIRE headlight (if u lamps fogged before, this will solve that problem)
    Step 20 reconnect that outer screw to the headlamp assembly and wait about 5-10 min for the silicone to dry
    Step 21 Re install headlights and get some hyper white bulbs for them corners
    Step 22 Give urself a drink for ur job well done
    Use this Tutorial at ur own Risk....I am not responsible for anything that happens to ur car because of this Modification
    Any Questions please PM me or Email me @ [email protected] If u dont feel like doing this, I will still clear corners of $50 a piece
    and one more pic by Maz!
    Revised By NycTrini
    Bronx NYC (reppin)
    3,489
    lol, took me awhile to notice thats my car on the far left. lol
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    San Antonio, Tex-Mex
    1,413
    Is this still valid Seth?
    <div class='quotetop'>QUOTE</div><div class='quotemain'>Any Questions please PM me or Email me @ [email protected] If u dont feel like doing this, I will still clear corners of $50 a piece Â*
    </div>
    Are you sure he's still down with this?
    <-Check it out Maz
    My 7g
    hey guys, of course i'll still do it, but thats not my email addy anymore, u can catch me at [email protected] ty
    North Bay...NorCal
    2,552
    yo bronxbomber! Your car and my car look almost Identical! Right down to the rims. What wheels do you have? what year is your car? Here are pics of mine... http://photos.yahoo.com/kimya_anderson
    bronxbombr's car is a 94 ES
    Bronx NYC (reppin)
    3,489
    Ya mines is a 94 ES with 16 soon to be 17 or 18's P racing. Notice the hump on my hood
    cloudkapri
    anybody want to do this over in like a table so that the pictures aren't blocking the text... or can somebody send me the instructions by email
    [email protected]
    there i fixed it
    if u have any questions, feel free to ask
    what about pics of a 94-96 i need to know those bolt locations
    basically all the same except by the base of the T of the TBar we have 2 bolts where the 97/98 have 4 bolts at the hoodbar
    ive been wondering..what kind of silicone is it that you use to reseal it? anyone know the name of it?would the headlight seal better if you were to scrape all the old silicone off and replace it with new?or is that too much of a bitch?
    2.4 liters of whoop ass.
    1,413
    Any Silicon/sealer will do.
    Scraping the old stuff off is a good idea, get that gunk out so that you get a better seal with the new stuff. :thumbsup:
    <-Check it out Maz
    My 7g
    i left the original in there and heated as i closed it up to get it sticky again, then i used clear DAP silicone and sealed them around the edges to make it air tight
    BEAST
    Probably gonna want to use 100% silicon
    Experienced TGC Member Lazarus's Avatar
    Jacksonville Florida
    1,409
    For those that did it how long did it take you from jacking hte car up to putting it back down? Took me about 8 house just to clear 2 headlights. That's Ludacris
    C.J. Cameron
    RETIRED TUNER!!!!
    "Keeping it Simple"
    1,409
    C.J. Cameron
    RETIRED TUNER!!!!
    "Keeping it Simple"
    1/2 hour to 45 minutes max
    thats jacking up bumper drop, clear, install back, and everyhting
    you guys jack up the car? :lauging: thats 10minutes wasted right there...
    1,409
    <div class='quotetop'>QUOTE(Nyctrini)</div><div class='quotemain'>1/2 hour to 45 minutes max
    thats jacking up bumper drop, clear, install back, and everyhting</div>
    I feel like an ass
    C.J. Cameron
    RETIRED TUNER!!!!
    "Keeping it Simple"
