Thread: Idles dangerously low when heat and defroster on
Showing results 1 to 13 of 13
    08-11-2002
    Waterbury, CT
    400
    Hey when my car is warmed up and i am on the road with my heat on or defroster, whenever i come to a stop, my RPMs drop very low to almost the 0 and stays there until i turn of the heat etc. Feels like its gonna stall. Then it goes to normal. It is fine when i am driving, only when i come to a stop it drops?? Any ideas. I tried to tighten my throttle...but does the same. My car idles like a little under 900 in park and 700-750 in drive. Please any help would be apreciated.
    my car used to do that. i'd shhift into neutral to ge the rpm's up there and even sometimes rev in neutral to keep it steady. i sould get the shop to tell me what they did to fix it...
    08-11-2002
    Waterbury, CT
    400
    so it was nothing major then with your car
    luxcrusr2000
    I had the same problem with my 6G. Believe it or not it was a faulty fuel filter.
    08-11-2002
    Waterbury, CT
    400
    <div class='quotetop'>QUOTE(luxcrusr2000)</div><div class='quotemain'>I had the same problem with my 6G. Believe it or not it was a faulty fuel filter.</div>
    Just curious......how much are fuel filter..ball park figure??
    San Antonio, Tex-Mex
    1,413
    Mine was $27 at Kragen, but prices in Alaska are outragous. I just did mine a few weeks ago, I can walk ya through it if need be
    <-Check it out Maz
    My 7g
    i really hope its the fuel filter. that shouldn't be too hard to change. but that wasn't the case with me. my car was at the dealer for half a week to diagnose and fix. luckily, i didn't have to pay the bill, it was cvaused by my accident
    08-11-2002
    Waterbury, CT
    400
    Ok cool, thank for the info. Well my car is going to the shop tommorrow so they can finally fix my speedo (my car has been stuck at 78,000 for like 3 weeks now, opps ) So maybe they can have a look.
    clean the throttle body. i garantee thats the issue.
    luxcrusr2000
    <div class='quotetop'>QUOTE(BLsGalant97)</div><div class='quotemain'>Just curious......how much are fuel filter..ball park figure??</div>
    It should run around $15.
    08-11-2002
    Waterbury, CT
    400
    Well heres something that puts insult to injury...now whenever my car idles too low...sometimes my radio just shut off until i turn off the heat/defroster, then it turns on. Any ideas??
    redlobster
    have you checked your battery or connections to it? When i put my new filter on i had to disconnect battery connections and i didnt put them on tight enough and the radio would shut off when i turned heater on and the lights would always dim, till i connected them tighter.
    not sure if thats it just putting in my 2 cents
    thanks
    sean
    08-11-2002
    Waterbury, CT
    400
    i'll go check the connections....cause my lights are diming alway when the heater is on
