i have a y-pipe sitting at home, i got it from another member a few years back. just pay shipping and it's yours.
There really isnt any performance gains to dual exhaust in anything. Hell I see alot of build turbocharged LSx motors running single's. Nothing wrong with a single, but if you absolutly cant do without the look, run a single back before the muffler then Y it off, its not really going to be dual exhaust, it will still give you that look though.
www.gooichimotorsports.com
-Pedro
Ya at the moment I'm teetering between getting dual exhausts. I love the look but I'm afraid its a little close to rice-looking. I dunno, if i find some cheap mufflers to dual with a y-pipe than i might do it.
Does anyone know how much hp is lost by adding a second exhaust?
I have the V6 model if that makes any difference
5-speed 6G72 w/ bolt-ons [sold]
'93 Nissan 240sx vert
couldnt tell you since theres no dyno sheet out tehre im aware of and you cant really guesstimate it either but it would still be in your best interest not to do it since it wasnt designed for it... unless of course you plan on spending the money to really have it done correctly
lose hp? i doubt that since there is less restriction on the flow
Shut up nooblet!! whats rice on my car??? If you gonna open your big fat mouth than have prove to back it up.
I also have a V6 with a dual canister mufflers set-up. I used a Ractive canister style with 4.5 inch round tips. All the members in the ATL area and also a few in the Savanah area have seen and heard it. The muffler has a nice low tone, and not the raspy ricer sound. However the shop that originally mounted this system didn't do the best job in the world, it was ok for the price at that time. They put more of a "T" in the piping, by branching the 2nd side off the original exhaust, rather than mounting a "Y" in the pipe further back. So now 90% of the flow comes from the original side and 10% from the 2nd. Also they are slightly uneven and hang too low. Every time I come off a decline or up an incline, they scrape a little and my car isn't even lowered. I plan on having it redone by a different shop,when it's closer to the time for me to lower and install my kit. But this time I'll be using a Y- pipe, and 2 regular style mufflers with smaller, oval tips for added ground clearance. This is the tip I'll be using for version 2.0:
It looks great when you get a body kit as long as the hole on the right side of the rear bumper is cut correctly and looks flush. Any suggestions on a kit I should get for dual exhausts?
Any body kit, really! I mean they don't make one for a Galant with 2 exhaust openings so you will have to make one yourself, so get whatever you like.
No, I meant what exhaust kit should I get? I was looking at GReddy.
I am not thinking about getting dual exhaust but i was just wondering, technically, why it would reduce performance to switch to it???
2002 Galant GTZ
1967 Cougar XR-7 w/289 c.i. (Project)
The difference would be unnoticeable if you just do 2 mufflers unless u run FI .... basically. You need true dual, you would get arguable more hp because of the exhaust goes straight to the muffler while the stock exhaust (y-pipe), the pressure would get built in the middle before being splitted on the rear/muffler again , hence less smoother flow.....
So it just comes down to preference .
i don't see why it would reduce performance
