Thread: Getting rid of distributor and running coil packs
Page 2 of 2 FirstFirst 12
Showing results 21 to 30 of 30
    I just test fitted the spyder CAS setup to both galant heads that are sitting in my garage right now and it fit both without any modification to the CAS cylinder or cam at all. I have some shitty cell phone pics that i'll post up here once they finish loading onto my comp.
    Pics:
    222whp/250wtq
    04-25-2007
    727
    hmm looks good... where did you get the cas from j-yard?
    Yup pulled it off a 2g spyder a few weeks ago.
    222whp/250wtq
    Cool. That is a different sensor than what I have. Yours is a 1 piece unit? When I did my conversion, i looked for some spyders, but there were none around. Good for you, It will save you the hassle of tapping the end of the cam like I had too. As a side note, the car is still running great with no hiccups from the cas or ecu swap.
    From the pictures, it looks like you got the sensor and housing from the 99+ Galant/Eclipse 4g64. Good to know they both work though, gives more options to anyone that wants to do the swap in the future.
    222whp/250wtq
    I wish I had a garage to work on my car in. :(
    141,000 miles.
    6 dents.
    Yellowed, cloudy headlights.
    spraypaint on the door panels.
    Could i use the 8g setup or not all of it.
    hey men, have u pics of the prossees?
    __________________
    -Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
    -Mitsubishi Galant LS 1994 a/t [ SOLD ]
    Posey
    me again... if anyone in or near las vegas that i can pay to do a ecu swap on my 95 galant. it have a 95 2g eprom...
    12-27-2005
    Charleston SC
    1,520
    Re: Getting rid of distributor and running coil packs
    Anyone else sucessfully done this?
    Sent from my SCH-I510 using Tapatalk 2
