Thread: Aftermarket Amp to Factory Radio
Showing results 1 to 8 of 8
    How can I add an aftermarket amp to my factory stereo in my 7G?
    09-25-2006
    Central, Cali
    1,145
    u can but ur going to waist alot of time doing rewirering everything my advise dont bother
    03 I4
    TGC Regular djflex167's Avatar
    07-21-2007
    Manhattan, New York
    709
    i suggest you better use a after market amp on a after market radio! don't even bother using it on oem stereo!
    That will be the way that I go probably later, but for now, I like the way my G looks with the clean factory look. I knew of this guy at a local install shop put in some infinity two channels in this Firebird running the factory radio, and it sounded damn good. I believe there is some sort of harness.
    Dont count on the speakers lasting long then....It can still have a "clean factory look" w/aftermarket speakers.
    2002 Galant GTZ
    1967 Cougar XR-7 w/289 c.i. (Project)
    Yeah, I'd just get aftermarket speakers. They aren't really all that expensive.
    Speakers are already done. I have Pioneer 6.5's in the doors, Pioneer 4X6's in the dash. I need to come up with a good 6X9 for the rear that is low enough to fit under the grill. I had some 4 way 6X9's but they are too big.
    I was able to fit my Pioneer 6x9 5-ways in the back.
    2002 Galant GTZ
