Thread: Bump Stops
Showing results 1 to 5 of 5
    Bump Stops
    Today I replaced my springs on my 7G. When I got to the rear, my bump stops were completely obliterated. Are there any aftermarket ones I can use to replace them?
    any parts store should have them....
    register! www.bordumb.com
    07-20-2003
    Orlando, FL
    3,168
    I would try to get them from Mitsubishi first. I believe they aren't more than $6 each.
    Now if you have no luck at Mitsubishi you can try Napa or any other local auto parts store. IF for some reason they can't find a application for the 7g Galant....tell them to search for a 2g Eclipse/Talon (95-99). I have ran into this before on certain parts that can be used from the Eclipse/Talon on our 7g when they aren't able to find a application for the 7g Galant.
    I just called the Mitsubishi parts dept, and thy quoted me a price of $19.00 each. They called them dampeners. Is this the correct name for this part?
    Yeah, Mitsubishi calls them dampers. $19 each is a lot. www.mitsubishiparts.com has them for $11.27 each. Of course then you would have to pay shipping. That stealership is robbing you.
    EDIT: What's funny is that if you look up the same part for a 2G Eclipse, it's called a strut bumper and is only $5.14 on www.mitsubishiparts.com. That's retarded. It's the same part. Tell your dealership you want them for a 2G Eclipse and maybe they will be cheaper.
