Thread: Pictures of Ignition timing jumper?
Showing results 1 to 2 of 2
    Does anyone have pictures of the ignition timing jumper for a 95 ES? I don't think I jumped it correctly and just want to make sure.
    Thanks in advance
    I noticed in the Brown Firewall plug, there is 2 little prongs inside once I remove the water cover from the plug.
