Thread: Questions about galants since u guy are pros
Page 3 of 3 FirstFirst 123
Showing results 41 to 48 of 48
  1. #41
    Quote Originally Posted by 6G72gearhead View Post
    Why? Hell the motor will probably get totally rebuilt at 100k, and a leak in the waterpump is going to develope gradually and not explosivly, I will notice it when it starts leaking. If I havent totally rebuilt the motor I will do the timing belt at 120k or when the water pump starts leaking, its not a big deal. Right now its on to a head rebuild and a coolent flush.
    The water pump is as likely as anything else to fail all at once. My wife was driving to her parents house one day and her water pump impeller shredded itself. The car NEVER leaked coolant, not even from the weep hole in the water pump.
    Vehicle manufacturers don't put maintenence schedules together for fun, they do it for proper maintenence of their vehicles. Risk what you want, but regardless my statement stands, why even risk a leaking water pump? Replace it at EVERY change of your timing belt.
  2. #42
    WarmAndSCSI
    I agree to an extent, but the impeller on the water pumps we have should never shatter. Some cars have plastic impellers and I've heard about those failing quite often. What usually goes wrong on our water pumps is the pulley. You'll start to hear the bearings going out with plenty of time to replace the pump, so it's not a life-or-death scenario.
  3. #43
    11-13-2007
    -OKC-
    3,970
    Quote Originally Posted by WarmAndSCSI View Post
    I agree but if you don't know crap about a car, a noise means nothing. Do you agree though that it is wise and good idea to replace it while doing the timing belt to save money since everything is apart anyway??
  4. #44
    07-19-2007
    Connecticut
    3,994
    ive heard that before, whats the harm to change it early and save a few $
  5. #45
    11-13-2007
    -OKC-
    3,970
    No harm, just some people speak from experience and some just read somewhere what could happen.
  6. #46
    WarmAndSCSI
    Yep, very wise.
  7. #47
    Quote Originally Posted by spardavr4 View Post
    Balance your tires dude. If they aren't balanced you can get vibrations. I forgot what my dad told me but at high speeds it's usually your back tires that aren't balanced. Correct me if I'm wrong Mr. Smartpants-es.
    ok, i balance tires all day every day. and unless the customer pays for a 4 wheel balance, i only balance the front tires. im not saying its right, but tire techs are usually swamped with cars, so we get stuff done as fast as possible. plus if the rear tires are only lets say 1/2 oz. off, its not gonna be that noticeable.
    but if all four wheels are balanced, then at high speeds the wheels are balanced. well unless the shop doesnt have a high speed balancer. most do tho. if it is computerised (most are) the wheels shouldnt have and vibration at any speed.
    vibration at the steering wheel could be caused by one or more of the following: out of round wheels, bad alignment, bad suspension, worn control arm bushings, worn ball joints, worn tie rods, wheel balance, separated tire(s), im sure im missing something, but im on my pain meds right now and cant think straight...
  8. #48
    findingyoshie
    Quote Originally Posted by Rusty View Post
    i would say re surface rotors cause it happened to me and now it doesnt shake
