Thread: Cigarette lighter not working
Showing results 1 to 12 of 12
    09-10-2003
    Charlotte, NC
    4,463
    Neither 12v source of cig lighter inputs are working. Is this a possible fuse problem, or wiring?
    05-31-2005
    4,735
    fuse
    or driver error.
    09-10-2003
    Charlotte, NC
    4,463
    It is a fuse? Nice. Now to find my manual to see which one..
    07-19-2007
    Connecticut
    3,994
    well i thought mine wasnt working bcuz it didnt turn orange when it was hot, i couldnt feel my thumb for 2 weeks :oops:
    there's a fuse...but check behind that panel my plugs fell out one day on its own and they didnt work, plugged it back in and it was good to go
    Experienced TGC Member SleekGTZ's Avatar
    05-09-2005
    Washington state
    1,065
    First check the fuse on the driver side panel fuse box (to the left of the steering wheel, you must have the door open).
    If that fuse is ok, it may be the "wire-fuse" that is attached directly behind the 12v sockets. That's what happened in my case. I had to remove those things and directly solder a new wire (regular wire). I have a picture of the back of the 12v socket showing that wire fuse, I'll post pics when I get home.
    Hopefully yours is just the regular fuse.
    09-10-2003
    Charlotte, NC
    4,463
    Mine was regular fuse, fixed. 15 amp fuse for future reference.. hoping the noobs will search
    07-23-2004
    San Diego, CA
    1,496
    Quote Originally Posted by SleekGTZ View Post
    hey sleek...do you know if there is a fuse behind the adapter (the one above the cigarette lighter)...mine doesn't work, but the cigarette lighter works...and i checked the fuse, and the wiring. nothing.
    05-09-2005
    Washington state
    1,065
    Quote Originally Posted by o1naturalhigh View Post
    In my case, each socket has a "wire-fuse" behind it aside from the regular fuse. So if your regular fuse is ok, and one of your 12v sockets is not working, then it's probably that "wire-fuse" that needs to get fixed (or soldered).
    07-23-2004
    San Diego, CA
    1,496
    cool...i'll look into it...thanks sleek.
    01-10-2008
    Oceanside/Camp Pendleton, CA
    1,848
    same thing happened to me, but what happened was the "nut" on the bottom outlet came unscrewed and was causing a short, so all i had to do is reach behind there and tighten her down and problem solved
    05-09-2005
    Washington state
    1,065
    Yes thats right, that could be the case too.
    In my case, I knew I've blown a fuse because I plugged in a 20 amp car heater but didn't realize that the fuse is only 15 amp. Then when I checked that the 15 amp fuse was ok, I had to look somewhere else.
