Thread: 3rd Brake Light Removal
Showing results 1 to 11 of 11
    galantguy
    How do you remove the 3rd brake light on a 2000 galant?
    I've got an LED brake light off the new BMW I want to install...
    davebernard
    Their are two or three 10mm Bolts in the trunk. then it just slides out.
    Yes there is 2 nuts on the underside of the rear deck lid also dont forget to unplug the wire
    STEPHEN
    2000 GMC K2500 4x4
    2004 Chevrolet Tahoe 4x4
    open the trunk. tist the bulb socket to remove the bulb and the socket. then u will see 2 10mm nuts. they are brass colored. remove them and then push up on the bolts. go to the back seat and pull up on the light and jiggle it towards u. if u have tint, be careful not to scratch that...
    I know this is an old post, I did not find anything newer. Since I got a spolier and now I want to remove the back seat brakelight. If I do, will there be a hole in the back window?
    yes, you can re-wrap it though
    00 Galant ES Turbo/5-Speed
    13 GTR
    11-13-2007
    -OKC-
    3,970
    Just unplug it and leave it there, that's what I did.
    Experienced TGC Member fliegendaffe's Avatar
    01-10-2008
    Oceanside/Camp Pendleton, CA
    1,848
    Quote Originally Posted by wittydrewy View Post
    rewrap it with accoustic fabric.
    i'm doing that and modifying my old 3rd brake light into a housing for tweeters to place on my dash.
    you could also use a t-tap connector and have 2 3rd brake lights.
    you could also get a hold of the panel from an old gtz without the hole for the 3rd brake light.
    TGC Regular djflex167's Avatar
    07-21-2007
    Manhattan, New York
    709
    led project sounds interesting, post picz when done!
    Quote Originally Posted by RAZ_76 View Post
    Second that.
    Black '02 2.4L ES ~ TGCLI
