Thread: Hood problem
Showing results 1 to 9 of 9
    Member
    08-08-2007
    Minneapolis, MN 55407
    151
    Hood problem
    So like when I bought the car everything was working perfectly. But now the freakin hood won't open when I pull the latch I'd have to have someone pull the latch while I open the hood with my keys. Just irratating cause I'd rather have it be open the way it should. Does anyone know how I can fix it by myself? if not probably have to take it to the shop and see what they do or say.
    08-01-2002
    Keokuk, IA
    8,348
    Adjust the two rubber bump stops on to of the radiator support, twist them out more so the hood raises up a bit. Problem solved!
    12-17-2004
    Louisville, KY
    4,328
    spray the shit out of your latch mechanism with some pb blaster or wd40.
    once all the rust is gone, then you can spray it down with some white lithium lubericant whilst working the mechaism back and forth.
    spray the springs, in between the latches,
    and then your problem should be solved.
    Both suggestions are on the money. It sounds like the latch mechanism is working because you write you are able to "pry" the hood up once the hood release is pulled. If the latch mechanism is working Seth's suggestion is what you need to enable you to open the hood with out "prying" it up.
    DOHCstunr suggestion will help the hood to move easier and respond better when the hood release is pulled but ultimately if the hood bumpers are not adjusted (Seth's advice) upward you'll probably still have a problem with getting the hood opened.
    jjj
    Senior TGC Member lonestar22's Avatar
    01-24-2005
    DFW/Stillwater
    2,752
    i have the same problem with my 7g, i can pull the latch and the hood wont pop, but i dont have to hold it open while i lift it, i just pull the latch and then pry it open
    07-20-2003
    Orlando, FL
    3,169
    I had this same problem when I first got my black 7g. Spayred PB blaster to looses up some of the rust buildup and then some sprayed lithium to the latch assembly. Since then never had the same problem happen again. Now another option is buy a new hood latch or find a salvaged 7g with a better condition latch and install it.
    Member
    08-08-2007
    151
    thanks seth it worked. Never knew that those rubber things were for that I always wondered what they were for.
    Yea i got the same problem. i just tap my hood a couple times and it pops up. But i have to take a screw diver to push the cable back in! If i bought new springs for my latch would that solve the problem of the cable not going back in or is my cable streched out and i need to buy a new one??
    1996 galant s
    If the cable is not pulling back the latch mechanism is the problem. Before replacing springs try DOHCstunr's advice to free up the latch mechanism. You should be able to lose the screwdriver...
    spray the springs, in between the latches, and then your problem should be solved.
    Use Seth's advice, "Adjust the two rubber bump stops on to of the radiator support," to make the hood pop up so you don't have to pound on it to lift the hood.
    jjj
