Those wheels are definitely going to rub with a drop. They're going to be sticking out well past the fender line as well. 8.5 in width and a +35 mm offset = skateboard look.
im looking for a set of wheels and the ones that i like have an offset of +35 and its a 19x8.5......will i have a problem with these and my drop on teins? i mean rolling or cuttin the fender is not a problem but im jus lookin to find out if ill have a problem
Thanx
Will definitely require rolling the fenders.
well i dont think it will have the skateboarder look...redgalant2k1 dont you have 8.5?? itll def stick out a little bit but i dont think ill do it neways due to the drop and i dont wanna shred my tires up
oo ok i gotcha....wuts the lowest offest we can go on the 8gs? i believe ive seen sum1 on tgc with +32 i believe he said they were VW wheels
Well I would recommend no wider than 8" and no lower than +35mm (on a 7" or 7.5" wheel) and +40mm on a 8" wheel.
If you installed a widebody or fender flares you could accommodate (and still look good) with a much lower offset and wider wheel.
On another note you won't fit the VW 5x112 bolt pattern on our cars.
iiiiiiiiight i got the offset crap now....thanx fellas.....oO and that guy with the 8g with the VW wheels, his car is black with the tein sticker on the rear triangle window...he was sayin he had 5x112 with the +32 offset and no1 believed him...i dont get how they fit cuz the stems are prob rubbing against the lug holes....oO wells
they will stick out i have 19x8.5 36mm offset and i only get away with it because of the jdm fender flares, which they sit inside with a mm or 2 to spare
I'm running 19x8.5 +45, fits just right.
thats me your talking about. and to this day my wheels still fit on a car that has a 5x112 lug pattern.
as far as fitment, my wheels have a 45 offset with an 8mm spacer to clear the small VW centerbore. the fitment is perfect in my eyes and i do not suggest riding with passengers in the back if you dont plan on rolling the fenders. ive driven from dallas to stillwater (about 250miles) on a few occasions and only rub about 6 times on each trip. i do plan to roll the rear fenders though, fronts fit fine
