Thread: knock sensor wiring
Showing results 1 to 14 of 14
    knock sensor wiring
    ne one know what the knock sensor wire colors are and how to wire it in.. Mine is from the evo 8 and it has red with black white wire and i assume i need red to goto the ecu and black white to be grounded but i dunno... Also whoever has a knock sensor what color wire is the ecu pin for the sensor.. Thanks for ne help
    u are correct
    WarmAndSCSI
    I'll see if I can find the ECU-side color while I'm at work, but I'll get back to you when I get home.
    knock
    cool thanks for the quick replies -- because i dont have the sensor im defaulting to low octane values so i had to use high octane values copied to the low octane but the main reason for the ecu is for knock control for me atleast..
    TGC Regular bmore303's Avatar
    03-11-2007
    Baltimore, MD
    773
    http://www.roadraceengineering.com/e...-ecuwiring.htm
    Not sure about the wire color, but pin number 78 is your man. Can you work from there?
    RIP
    1995 7G 4G64 / 63T DOHC Turbo
    Part Out Coming Soon
    In search of 2G 3000GT VR4
    Daily driving
    Dat '08 Cobalt Coupe
    WarmAndSCSI
    Quote Originally Posted by bmore303 View Post
    Thanks bmore, now I don't have to look. haha
    thanks -- i have the pin number but im using an extension harness and i was curious if the wire matches the color of the stock knock sensor wire...... i guess im paranoid but ill hook up the wiring today and see if i get some reading -- ne know how i can test its active -- should i get some voltage at idle like 1v or something......
    03-11-2007
    Baltimore, MD
    773
    Dunno, but I'll check EvoM in a few minutes
    Pin 78 should be one of many White wires...so you still need to count lol.
    Knock Sensor = 5v.
    Min = 0v
    Max =5v
    Anything 1v over your normal is a sign of detonation. What's normal on the 64..I don't know.
    RIP
    Daily driving
    ok so it should not be 0v am i correct in assuming that??
    goosey where did u tap for the knock sensor -- the place i thought is not threaded and i cant find another location from the top of the car atleast???
    03-11-2007
    Baltimore, MD
    773
    Correct, it should never read 0v.
    RIP
    Daily driving
    knock sensor
    I have the hole for the knock sensor but does ne one know what size its supposed to be tapped for because its not threaded... Its the only whole that looks like anything i can use.. My sensor fits in it perfectly but its not threaded so.... Thanks
    the whole i thought it was supposed to goto is the right place its threaded but u gotta be perfect to get it to screw in -- it was a pita to get that in there but it works finally -- i read .30 to .40 on idle and when i revved it hit .60ish so it works
    logs
    here is a log of two wot runs..... with evo ecu pulling timing haha
    Attached Files Attached Files
