Thread: leaking out the back?
Page 2 of 2 FirstFirst 12
Showing results 21 to 34 of 34
    07-19-2007
    Connecticut
    3,994
    alright, can i use regular scotch double sided tape or do i need a better kind?
    04-10-2005
    NYC
    3,695
    probroblly is the altezzas a lot of people with them had that problem
    Your doors are still leaking? Check the water drains on the front and back of the door and check to see if they are blocked.
    07-19-2007
    Connecticut
    3,994
    is there any type of sealer i can spray in the huge gap that will still allow me to take them out when needed?
    07-19-2007
    Connecticut
    3,994
    Quote Originally Posted by spardavr4 View Post
    what water drains?
    and yes. im doing the evap drain next weekend with a friend, but the doors, i just think the front door (Which i never checked) that i put the bottom seal back on wrong... but if you can tell me about the water drains lemme know
    07-19-2007
    Connecticut
    3,994
    i got some silicone sealer for the tails. going to do it on the next hot warm day. for now its all taped up. thanks to everyone that helped
    as always, i really appriciate it
    weatherstripping would be a more permanent solution to sealing that gap. sure its not as cheap as duct tape but you'll have a nicer result.
    07-19-2007
    Connecticut
    3,994
    i dont mind not cheap when it involves water runing the inside of my car, for now im going to attempt to use the silicone that NAPA had me try, then ill go to weather stripping if needed. how would i do that tho?
    WarmAndSCSI
    I would suggest just running the weather stripping around in a circle around the hole. Spiral it around until the harness is wrapped.
    07-19-2007
    Connecticut
    3,994
    thanks, should i do that ontop of doing the silicone?
    WarmAndSCSI
    Eh, that might be overkill ;) It's up to you and how messy you want to make this job.
    07-19-2007
    Connecticut
    3,994
    where can i pick up some weather stripping? like autozone or advance auto? and is there a certain kind that i need or anything will do?
    WarmAndSCSI
    Any auto parts store, really. Should be black and come in a roll. It's just automotive weatherstripping.
    07-19-2007
    Connecticut
    3,994
    thanks again, ill find a way to get all the water out of the trunk, get it nice and clean, and run a shit load of water on the lights to test it... good idea or no?
