Thread: m3 mirrors?
Showing results 41 to 60 of 79
  1. #41
    BuZZeDCooKieS
    would mirage m3 mirrors fit?
  2. #42
    hmmmm my sister has a Mirage lol maybe this weekend...but i am shooting for those test fit of the accord mirrors tonight and then maybe finishing up both my mirrors...good luck to me
  3. #43
    IllestGalant
    good luck seth, your like our guinea pig, just joking thanks for all the info
    now get back to work, just joking again
  4. #44
    well tried the accord mirrors tonight and the base is a lot larger(even bigger than the 2g base) so this Sat i am going to mod the base of the 2g mirrors to make em fit. untill then!
  5. #45
    good news guys i was messin around with the mirrors and screwed the bottum left side into the original hole and everything lined up! (not the other holes, just the outside ) I have drill 2 new holes for the top and far right and do just a little bit of sanding cause the base is a tad too long but they will fit!
    im going to install them tomorrow and then do some sanding and fine tuning this weekend but thats about it...
  6. #46
    Up top where the base is kind of curved, i am going to sand that down so it is straight and it will flow with the trim
    I am going to sand down the base here so the mirrors fit on flat
    and finally i am going to sand a tad where the base and the window meet cause towards the bottum the base gets longer than what it is at the top
    other than the sanding, some weather stripping and the wiring, they are done i am planning on having them both sanded and wired by Sat or Sun...
  7. #47
    When your fully done ( bolt them on and get them hooked up to the power window) give us every step including pic!! For thoes that want to do this (me me me me!!!! )
    YES I STILL HAVE MY GALANT!!
  8. #48
    i got the wiring for the mirrors done kidna just not the LEDs...only problem is i cant get the mirror to move left to right, i only can get it to move up and down. o well ill figure it out this weekend. I hooked the LED lights up for a few seconds and they were pretty bright and Blue! hehe they will look good at night
  9. #49
    San Antonio, Tex-Mex
    1,413
    Excellent work Seth :thumbsup:
    <-Check it out Maz
    My 7g
  10. #50
    BEAST
    Aww excellent. Can't wait to see the final product.
  11. #51
    tightgalant
    so what ended up fitting, the accord ones??
  12. #52
    2g eclipse ones...tried to fit on the accord ones, but the 2g ones will take less modding. alls i had to do was a little sanding on the base and drill 2 holes per mirror. i have them both on now, only thing left to do is weather strip em so they dont leak, walmart was out of weather stripping otherwise that would be done too. more pictures up tomorrow...
  13. #53
    well they are on, nothing left to do except weather strip and wire em but its too cold again :cry:
    ill get some better pics tomorrow my camera was being retarded and took small pics. FIY i washed my car yesterday, but it snowed for about 2 hours on my trip back up to my dorm, go figure
  14. #54
    not bad seth good work
  15. #55
    BEAST
    Nice bend in your license plate. Is that custom? The mirrors look great!
  16. #56
    haha thanks...the bend is custom had a shop do it for about $150 i couldnt afford the otherside, too expensive supposed to add about 50hp from aerodynamics
    i dont know how that happened i tried bending it back with my foot, but it didnt work :lauging:
  17. #57
    IllestGalant
    dude, just take the bitch off and bend it
  18. #58
    haha too much work for how cold it is here :cry:
  19. #59
    o0 XeRO G 0o
    the mirrors look great seth, dont forget the tutorial
  20. #60
    dont worry a tutorial is to come...even though its easy enough you dont need one
