Originally Posted by
beam514
5 speed is mated to the engine. I used the engine hoist to lift up the transmission into place. That thing is a BITCH to line up with the engine. It kept hitting the pressure plate.. got it all scraped up :( but whatever
Plan for tomorrow is:
Day: clean, put all the mounts in place, reattach starter motor, raise up the entire assembly again, bolt it to the mounts, attach the shifter cables, run the clutch lines
Night: reattach the axles, fill clutch lines, bleed clutch, flush transmission with cheapo gear oil, then fill with Mobil 1 synthetic 75W-90
then.. start her up?! I hope
