Thread: beam514's 99 Galant: 3.5L Swap
Page 24 of 28 FirstFirst ... 14202122232425262728 LastLast
Showing results 461 to 480 of 551
  1. #461
    10-18-2007
    Glen Burnie, MD
    1,314
    BETTER TIRE MOAR LOW! ASAP! thx
  2. #462
    haha, knew it was RPF1s, size, offset?
  3. #463
    10-18-2007
    Glen Burnie, MD
    1,314
    17x8 40et maybe?
  4. #464
    Uuuuu. now you did it. Now you have to give the g some more of that color somewhere else.
    Quote Originally Posted by Corey2kG View Post
    Hmmm moar purple imo I like the wheel style though.
    No. That would be ugly and overdone.
    Quote Originally Posted by greddy View Post
    17x8 +45.
  5. #465
    05-03-2007
    Socal/Central Coast
    3,803
    I don't know where else I would put more purple.. lol
    and I would LOVE to go lower, but the driveways in Socal are killing me. I already scrape as-is..
    Specs: 17x8 +45 on my old 215/50/17
    and I forgot to mention, these are actually candy purple so in full sunlight they are almost pink:
    with flash:
    without flash:
  6. #466
    05-03-2007
    Socal/Central Coast
    3,803
    17x8 +35.
    actually they're +45, and I'm quite glad they are, because the fronts are already almost poking. +35 and I would be a skateboard lol
  7. #467
    hahaha, I can't believe I didn't even remember the offset, I'm glad they're working out for you.
    Pictures won't load for me for some reason though :(
  8. #468
    08-18-2004
    Charlotte, NC
    1,029
    U joking right. Focus bro. Focus
    No, a lot of 2G guys have done this. If they can't find a 482/399 MAS, they will get a 501 MAS, remove the airhorn and use the 482/399 MAS scalar & compensation maps. The Evo MAS flows like 1 lb/min more the Eclipse GTS/Montero 3.5 MAS.
    1994 GS FYI
    DSM/CSM Manuals
  9. #469
    04-08-2010
    Springfield, Mass
    1,225
    Nice purple rims lol they look great on the car
    «Carlos»
  10. #470
    06-13-2008
    Bronx, NY
    2,606
    Ohh i see yoy mean the metal honey cone pattern. I put the evo maf and chaned all the maf map to the evos. Works great after a few minutes i see the responce right alway. But after a few min idle drops and afr goes rich and lean. I think i need to adjust more of the timing at idle.
    SOHC Turbo
  11. #471
    06-13-2008
    Bronx, NY
    2,606
    Beam. Find out for me your TPS % on evoscan when engine is on idle. foot off pedal.
    Thanks
    SOHC Turbo
  12. #472
    04-29-2009
    Holyoke,Massachusettes
    3,600
    ^^ coming from the purple king lol
    FreakyDeaky
    2kG 6g72/74 5 speed
  13. #473
    05-03-2007
    Socal/Central Coast
    3,803
    Quote Originally Posted by 99galantES View Post
    haha yeah thanks. I have actually had this sitting at the house for over a week, and when I saw all your purple stuff, I was like oh sh*ttttttt lol
    Isaurio,
    TPS is at 12.15686% at idle, jumps between 718.75 and 750 RPM for idle, sometimes even 687.5
  14. #474
    04-08-2010
    Springfield, Mass
    1,225
    I want a lil more purple on mine
    «Carlos»
  15. #475
    06-13-2008
    Bronx, NY
    2,606
    Isaurio,
    Really do you get a smooth idle or it jumps a little. how about when pedal on WOT. put your foot all the way. i see the PCM is looking for 95 to 99% on the TPS on WOT. i have 7% and is fine at that level but i think is not 100% right. I need to adjust that 100% for tuning reasons. If your tps readings are off it will mess everything in the tune. I will try 12% + more. I found out from factory some tps reads 20% at closed. I was thinking it needs to be at 0% bad idea LOL
    SOHC Turbo
  16. #476
    Isaurio,
    Nah you're good. I didn't even have a TGC account when I found these, thus you're not a biter haha
  17. #477
    05-03-2007
    Socal/Central Coast
    3,803
    Really do you get a smooth idle or it jumps a little. how about when pedal on WOT. put your foot all the way. i see the PCM is looking for 95 to 99% on the TPS on WOT. i have 7%. I will try 12% + more. I found out from factory some tps reads 20% at closed. I was thinking it needs to be at 0% bad idea LOL
    it's pretty smooth, but jumps every once in awhile. I have some WOT pulls so let me check them out for TPS %.
    I think WOT sees about 96.47%
  18. #478
    05-03-2007
    Socal/Central Coast
    3,803
    yeah I've actually been wanting to do either orange or purple for awhile. Green was my top choice but ASTIG already claims the green wheels lol.
  19. #479
    06-13-2008
    Bronx, NY
    2,606
    OHH OK THATS ABOUT RIGHT. if it gets jumpy bring it up a little. but remember the old settings. Remember you are using the G PCM. do a 15%
    SOHC Turbo
  20. #480
    05-03-2007
    Socal/Central Coast
    3,803
    how are you adjusting the TPS reading?
    EDIT: are you adjusting the function that EvoScan uses to calculate it? currently it is:
    TPS = x*100/255
    so you're saying to make it:
    TPS = x*100/255 + 3
