I'll do it as soon as I get home.
oo good idea, i could use some of those too
how about a top view if possible?
'91 Kawasaki ZX7 (SOLD)
'95 Kawasaki ZX9R
Looks like its a teeny bit off to the driver side (on the top of the wing - as in towards roof)
Black '02 2.4L ES ~ TGCLI
what do u mean he's off i think it looks perfect
'95 Kawasaki ZX9R
It looks off because it doesn't look like it is bolted down. See how the top is lifted a little bit.
'95 Kawasaki ZX9R
:) Yeh that's what I meant. My bad.
Dude, you know the rubber stoppers?? Unscrew those and that's one hole, go from there. You have to get it right the first time or you will mess up your trunk. If you make a mistake and drill the hole off just by little bit and the bolt wont work.
This is what I did when I installed mine.
Take 2 boxes, set one leg on one and one on the other. Outline the shape of the leg on the box. Now measure length and width with a measuring tape and transfer those measurements on the box, drill the holes you just measured in the box. Set the spoiler back on and see if the holes match, make adjustments. It's better to go thru as many boxes as it takes then make a mistake on your trunk. Once you have it right, cut on the outline and set it on your trunk. Now you know that it will fit exactly like on the box.
Let me know if you need more help.
thanks RAZ but once i get it and if i have any problem ill let u know, if u can get me some pics of the inside that will be great
'95 Kawasaki ZX9R
The front one on the left you will need two holes, one is small and one is about 3/4 of and inch for the harness. Hang on, let me see If I can get good photos for you. BRB
I remember that the right side had 2 holes and the left side had 3 holes. 2 holes on each side for the bolts and one extra on the left for the 3rd stop wiring.
Yup! Here, I did my best with my phone camera. The front hole is 1" from the side of the trunk lid.
HERE IS THE RUBBER STOPPER
HERE IS THE BOLT UNDER THE RUBBER STOPPER
THE FRONT HOLE
THE BRAKE LIGHT HARNESS IS UNDER THE TRUNK.
awesome pics raz thanks but i didnt understand what u said about the wire, what do u mean under the trunk ??
'95 Kawasaki ZX9R
In that last picture, do you see where the harness is coming out of??? I cant photograph that. The harness should have a rubber gormet on it that if you cut the hole just right, it will fit nice and tight so water doesn't get in there.
goose if your calling me a noob then ur the noob my friend.
we joined the forums the same time
and btw where did i say you went to the shop for everything?
i didnt refrence your name for anything, all i said was maybe some people like to learn
learn to read
ZIGONATOR
oh boy, dont attack goose, lets just keep this thread clean
those pics of Denvers spoiler, is it suppose to side like an inch or two forward like that?
denver said about the length of the first knuckle of your thumb so i wanna say about an inch
'95 Kawasaki ZX9R
how come? any reason or...
i dont doubt it, ya know? i just want to know before i do mine
'95 Kawasaki ZX9R
