What's the best brake fluid for our cars? Brands? Dot 3? Dot 4? Gonna put stainless steel lines and gotta blead the system.
I use motul 5.1
www.gooichimotorsports.com
Whats the difference btween dot 3 and higher? I was reccomended dot 6.
DOT3 & DOT4 fluids are interchangeable, only difference is their boiling point. Just don't use silicon based brake fluids or it will cause your seals in the master cylinder and calipers to malfunction. Only use glycol based.
Use DOT4 whenever possible.
About how much bottles do I buy?
A 5.1 is compatable with an abs system as well. It has a 500* or higher boiling point. Dont use regular dot 5, it has to be 5.1.
i still have the factory brake fluid in mine (78k miles)... i should probably change it right?
hhhmmmmm
