Thread: vibrations
Showing results 1 to 5 of 5
    vibrations
    I am having a problem with my car, it seems to be vibrating a little too much when i put the car in gear , only when its cold and i put the ac on , i just replaced all of the mounts , the car has 90 thousand miles on it but maybe I am thinking a new ac clutch is need and the old one is shot throwing the whole engine or belt system out of balance .
    have u cleaned the throttle body?
    11-13-2007
    -OKC-
    3,970
    I have one if you need another one.
    yes and i cleaned the mas air flow sensor a long time ago replaced the plugs and wires
    has anyone ever heard of replacing the balance shafts ? it seems like the engine is loping slightly once every third revolution or so
