Timing a 2.4 SOHC, '01 Galant
Thanks in advance for any help you may be able to provide. I have a 2001 Galant, 2.4 L, 16 valve, SOHC. A new timing belt, balance shaft belt , crank sensor, cam sensor, and injectors have just been installed on this engine. The engine starts up properly, but the throttle response is very slow (almost as if timing is retarded), and it is hard to get the engine up to 2000-2500 rpm, before it starts to spit, backfire, and just plain runs very poorly. First question: Where are the timing marks for this engine? I have timed the balance belt with the arrows and notches as marked on the case and on the gears . This belt was not damaged, but it was replaced anyhow. There appears to be no problem with aligning those marks. The main timing belt was aligned as follows: Cam gear marked notch at the top, aligned with the hash mark on the valve cover end surface. Crankshaft blade notch aligned with the raised mark on the case, about 10 o'clock. Oil pump gear mark aligned with the raised mark on the case, about 10 o'clock. Belt installed, and tensioned. Recheck all marks, and they appear to be spot on. Second question: Is the crankshaft mark aligned properly, or should the balancer notch be aligned to the lower cover TDC mark instead of the crank blade notch alignment to the case mark? If someone can post a picture it would be extremely helpful. Thanks, David.
Member
timing
i did my belts one in a 98 and one in my 00 and i used the nothch in the crank shaft sensor , the one on the crank shaft cover never seems to align perfectly anyways
Member
tps?
sound like your throttle position sensor is bad
