i am having the same prob w/ my right signal... idk either
circuit breaker? for what?
if you've ruled out the bulbs, and the wiring, and the fuses, i say look at the socket. how are the contacts? are the contacts, contacting the bulb?
looks like you ran out of turn signal fluid.
explain what "going crazy" mean?
how did u check to see if the bulb is contacting with the socket??
the turn signal bulb wiring is simple. ground goes to ground and the positive pretty much just goes to the etacs ecu.
did u do anything like switch bulbs or use LED's? fast clicking meaning the lights are flashing fast or u just hear sounds? give us a better description of exactly u r seeing/hearing... btw, there is no circuit breaker for the signals... do u mean flasher module? the ETACS ECU controls the blinkers. did u just install different tail lamps (JDM or altezza)? the signals should not affect the parking lights or brakes... sounds like a misswire or crossed circuit. need more info to diagnose.
It could be the flasher unit. You'll find it under the steering wheel dash, it's a module with harness attached to it, turn on your car, then turn on the signal listen for the sound and you can easily find it.
- If you've got nothing nice to say, what the hell is wrong with you!?!
ok well i was under my dash for some time and everything appeared normal
and the ticking is coming from one of the 2 boxes white or black i got to take apart the black one and see whats up
on the other hand the 2002 i4 guys tell me if u have something different from the pics cuz thats what i have
I had the same issue and it was the turn socket. Replace it and everything works. I could not believe it. Socket looked fine.
Mine was the front one.
check your bulbs first, then look under the dash by the kickpanel and you should see a little black or silver box in one of the fuse sockets. Makes sure its the flasher and not the relay, sometimes maybe if you are not the first owner the flasher may have been changed so it also may look like a little round silver thing in the fusebox. You can replace it with any #552 flasher from your handy autozone or parts store.
Drive It Like You Stole It!
7G Erubini Body Kit for sale
