Thread: For those wanting to do a DOHC swap!
Showing results 1 to 12 of 12
    08-18-2004
    Charlotte, NC
    1,029
    1994 GS FYI
    DSM/CSM Manuals
    made sticky
    old news
    the link doesnt work guys!
    Member JDM4G64T's Avatar
    07-09-2007
    Fort Lauderdale, FL
    324
    Quote Originally Posted by galant3333 View Post
    x2
    Car is sold, no more G.... Moved on to something a big more sporty.... lol
    08-18-2004
    Charlotte, NC
    1,029
    1994 GS FYI
    DSM/CSM Manuals
    timing belt
    It was autozone bein stupid swaps all done now dohc ftw
    2002
    4g64 dohc turbo 5-speed
    gt30r @20psi stock block,mbc
    2.5" tbe
    evo 8 ecu and maf
    EDIT: started a thread with my question
    2002 5spd swapped
    under construction.....
    is there another link for the swap. Tried all the links, but they're all dead. Is there any updated links somewhere?
    https://www.thegalantcenter.org/showthread.php?t=43258
    try this if you need more search here or club3g there is tons of info out there
    2002 5spd swapped
    can someone please verify if this is true.. http://forums.evolutionm.net/3359490-post35.html that we can use a timing belt off a Hyundai Sonata 2.4 instead of buying cam gears and degreeing them. and also can we get away with using our stock water pump?
    Evo 8 Head, BC 288/288 BC Springs & Retainers, Weisco Pistons and Eagle Rods 2.4 (Comperssion 9.5:1) ARP Headstuds and Mainstuds, Cosmetic Headgasket, New Clevite Bearings all around, Evo 8 Oil Pump, English Racing water pump, Gates Racing Timing belt, Findanza Adjustable cams, 2 255 walboro pumps, RC 1000s, AEM Rail, and 5 Speed swapped, powered by a 6262 T3 w/ .82 A/R.. WILL MY TRANNY HOLD THIS? Lets wait and see :)
