Thread: iac motor
Showing results 1 to 6 of 6
    iac motor
    i think my car needs a new iac motor when i turn the ac on the idle stays the same and does not go up to 1000 like normal and i am gettting a vibration when i put it in gear. I cleaned my throttle body a long time ago and now i think the iac motor is completly read ,causing this problem
    Bronx NYC (reppin)
    3,489
    make sure its really the IAC first, its an expensive part.....I do have 4 of them here in my job.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    i dont think that its your IAC because when mine went bad my car wouldnt run at all. The idle would bounce up and down and then the car would stall and cut off.
    11-13-2007
    -OKC-
    3,970
    1000RPM is not the normal range. I believe is between 600 to 800 something. MIne has always idled at 800.
    Quote Originally Posted by bronxbombr View Post
    I agree.
    iac motor
    well then what besides engine mounts would cause the maybe the transmission mounts or the other mount on the left side they both look fine but do you think i can get the best look if i remove them first? i get a vibration only in gear especially when the ac kicks on and the lights are on , only in gear.my car idles normally at 750 .it only goes up to 1000 when th eac kicks on in the summer time in park.
