Thread: Oil Pressure Sensor Location
Showing results 1 to 20 of 20
    I searched the forum and i couldnt get a clear answer.
    where is the Oil pressure sensor/ switch located....
    if you have a picture it would be great....
    thanks
    2000 I4 100k Miles
    04-10-2005
    NYC
    3,695
    it is above the oil filter
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    thats the v6 isnt the I4 on the block like somepalce i tryed lookngi for it once and i failed lol, manual said it was on the block
    <a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&amp;current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
    08-04-2003
    NY
    4,344
    Its on the back of the block just below and to the side of the intake manifold support bracket.Its brass colored (probably made of brass too?) and hexagon shaped.
    99' Galant ES
    4G64/63T
    AEM EMS
    ok i see it.. yes stewi is 100&#37; right on the I4
    when ill change mine, ill take a picture and post it,,,, next week
    2000 I4 100k Miles
    Experienced TGC Member dwjp90's Avatar
    04-13-2008
    west chicago, il
    1,150
    yu will see some oil in the pic dont worry i not leaking oil, wit for your engine to cook down be fore you remove the sensor 8p being angry and in a hurry dont mix well
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    stupid factory manual, i thought it was on the exhaust side, now if you where to add a electionic oil pressure sensor?, you tap into the wires or the block lol
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    where are the other sensors?
    08-04-2003
    NY
    4,344
    Quote Originally Posted by duh2150 View Post
    you source it from the block. never tap any aftermarket gauge into a factory sensor, your asking for trouble. not only will it mess with your reading, but it will probably F'up the signal going to the ECU from the sensor as well. The best place to install an oil pressure gauge is right on the oil filter housing.
    99' Galant ES
    4G64/63T
    AEM EMS
    i have a leak like that too,,,, i wounder what it could be,,, ill find out on saturday
    2000 I4 100k Miles
    ok i just changed my oil pressure sensor $20 from the dealer. you will need a 1 1/6 inch deep socket and it should take 5 minutes to change, This is for the I4
    you will need to change the sensor if your oil light comes off and on during idel and goes away when you rev it..
    2000 I4 100k Miles
    04-13-2008
    west chicago, il
    1,150
    Quote Originally Posted by ChiGalant View Post
    omfg thanks that has been driving me nuts i installed a preaussure gauge and it read 10-15 when i would idle and the light would come on ill find a mitsu dealer and ask for the part
    04-13-2008
    west chicago, il
    1,150
    yay it worked
    Thank you for the post. I just changed mine out. Dealer wanted $40, autozone charged $6.
    "If Wal-Mart is lowering prices everyday, how come nothing is free yet"
  15. #15
    You are here entirely tooo much!! Serstylz2's Avatar
    09-10-2003
    Charlotte, NC
    4,463
    Quote Originally Posted by dwjp90 View Post
    So i am assuming i need to get a phillips head and remove that tab, then use the socket to remove the sensor?
  16. #16
    09-10-2003
    Charlotte, NC
    4,463
    changing this soon.. any tips appreciated
  17. #17
    Experienced TGC Member DryBear's Avatar
    11-05-2003
    San Francisco Bay Area
    1,517
    Quote Originally Posted by Serstylz2 View Post
    No need to remove the tab - just pull off the connector that connects to the tab. Don't forget to use some thread sealant, and careful not to get oil in your eyes.
  18. #18
    09-10-2003
    Charlotte, NC
    4,463
    wait is oil gonna be pouring outta this thing once i pull it? dangit
  19. #19
    11-05-2003
    1,517
    Well, when I changed my sensor out, I did an oil change at the same time. Kill two birds with one stone.
  20. #20
    09-10-2003
    Charlotte, NC
    4,463
    tru. just changed it out, wasn't too bad, some tips are get the 1 1/16 DEEP SOCKET.. which now that i look up there it already says so... and jack ur car up as much as you safely can for leverage, i ended up shifting my body to the left of the car (head was facing downward towards rear bumper) and pressing my wrench outwards towards the pass. front wheel to finally get it to loosen
