i think if you remove the trim piece, there a little bulb i forgot the bulb size but it clips out.
Hey, Im new to this forum so if this topic was already posted sorry. So I have a 99 GTZ, and the shifter light (one that illuminates the gears) is out. My question: How do I get to it? Please help??? Thanx
Robert
00 Galant ES Turbo/5-Speed
13 GTR
the piece he described can be pryed off with a small flat head screwdriver , be carefull not to hurt the edges, start at the sides , once you get that piece off you need to remove the shifter, the screw is located to the side of the shifter once you do that the button will fall out be careful not to loose all the parts the spring , and the button , then remove the screws at the base of the shifter and the cover comes off then unscrew to bulb fixture , replace the bulb and reassemble in the reverse order.
Thanks for the directions. I will try working on it today. Again thanks for help.
Done. It wasnt that bad. Thanks
its pretty easy all you have to know is how to use a screwdriver and your alright , if i had to explain how to rebuild a transmission you would be in trouble , lol
Hmmm, I have a shifter boot covering mine. I haven't seen that light in quite some time,lol
thats because u have a standard .lol
anyone know the bulb for the ac? controls i got one out pissing me off lol
<a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
open the panel and then go to radioshack and match it up , re use the cover on the bulb
*sigh*
the top sticky in the main 8G forum is an entire bulb list for your car.
https://www.thegalantcenter.org/showthread.php?t=14195
