Thread: Tensioner
Showing results 1 to 2 of 2
    Member
    08-08-2007
    Minneapolis, MN 55407
    151
    Tensioner
    Where is the tensioner located for the 1995 Galant is it the one by the alternator? or is there another one cause I have to adjust my tensioner since it's kinda destroying my alternator belt.
    Its on the alternator kind of towards the top front. Theres a 12mm bolt on the top side which you have to undo to loosen/tighten the tensioner. On the front, I think its a 10 or 12mm that is that actual bolt you use to tighten/loosen the belt.
