Thread: 1g gearbox
Showing results 1 to 5 of 5
    1g gearbox
    I need some info about the 1st gen turbo gearbox, if it bolt on , on a 7g 4g64 block.
    and if the axles will be the same
    the 7 bolt 1G trany will bolt on, but thats it. you wont be able to drop it in the bay. thats because the 1g trany doent have the rear mount, and this one is mounted to the 1g engine. So it pretty much impossible to do.
    the tranny is from a 6 bolt 1g.
    For the rear mount is no problem, cause the rear mpunt i've bolt it on the engine block
    (91 Galant VR4 1036/2000)
    In The process of rebuilding.
    Will my 7G housing fit up to this 4G63?
