go to your local hardware store they sell these "stripped bolts" removers..works great. ask somebody at the store and they'll direct you to what you need.
I'm probably about 2 or 3k miles over my oil change but i can't get the bolt off! i don't remember what the hell i did last time i changed the oil bc the bolt is sooo tight that the head of it is almost rounded off. What can I do to get it off without bringing it to a shop (i will if i have to). I was thinking of using vice grips.
1999 North Star White V6 8G
2003 Yamaha R6
2008 Lancer Evolution X
The Original FACTION from the BGR Days
First Founder of TGC Florida 2002-2005
Cali: Sig 3/28/2011
the bolt itself isn't stripped, the head of the bolt is almost rounded off
2003 Yamaha R6
Yeah, thats what Cali is talking about. Its basically a socket with sharp insides that dig into the bolt head and lets you unscrew it. You can get a kit(just different sizes) at AutoZone or anywhere. Just would need a new oil drain plug once its all said and done.
Yes get what cali said, and change your oil more often. :)
Love,
Matt
i just use a set of vise grups in the past. those removers sound easier than the vise grips. just make sure to buy a replacement drain bolt before starting.
I assume you are turning it the correct direction? It seems that people get confused for some reason when they are laying down. As a former Cadillac technician, I would recommend the properly size 6 point socket (they don't slip as easily at 12 points), and brute force. If it still slips, use vice grips. Then go buy a new drain plug so you aren't screwed the next time you need to change the oil.
Good Luck!
-Jeremy
1964 Impala Convertible
1989 Dodge Ram 50 w/ Turbo 4G63
2005 Subaru 2.5 RS
2006 Subaru Legacy GT
My Car Blog
i bought a pair of vice grips and a new bolt from the dealer. I'm gonna use the grips and if it doesnt work, im going to get the tool cali was talking about
ill keep u guys posted
2003 Yamaha R6
Let us know how it turns out. If for some reason you cant get it out, I got a used good condition pan/plug I can sell you cheap. Assuming you have a 4G64.....
4G64/63T
AEM EMS
came out easy after a few tries. oil was really dark, im guessing about 3k miles overdue? So my next change is in 1200 miles
Thanks guys!
2003 Yamaha R6
Castrol oil loves Galants
i used castrol before today's oil change. i filled up with mobil 1 this time
2003 Yamaha R6
